Servo motor with heart rate sensor
I am trying to use both the servo motor and the heart rate sensor but without success :frowning:
Here is the code I tried:
#define USE_ARDUINO_INTERRUPTS true // Set-up low-level interrupts for most acurate BPM math.
#include <PulseSensorPlayground.h> // Includes the PulseSensorPlayground Library.
#include "ServoTimer2.h"
ServoTimer2 servo1;
// Variables
const int PulseWire = 0; // PulseSensor PURPLE WIRE connected to ANALOG PIN 0
const int LED13 = 13; // The on-board Arduino LED, close to PIN 13.
int Threshold = 550; // Determine which Signal to "count as a beat" and which to ignore.
// Use the "Gettting Started Project" to fine-tune Threshold Value beyond default setting.
// Otherwise leave the default "550" value.
PulseSensorPlayground pulseSensor; // Creates an instance of the PulseSensorPlayground object called "pulseSensor"
Serial.begin(9600); // For Serial Monitor
servo1.attach(12);
// Configure the PulseSensor object, by assigning our variables to it.
pulseSensor.analogInput(PulseWire);
pulseSensor.blinkOnPulse(LED13); //auto-magically blink Arduino's LED with heartbeat.
pulseSensor.setThreshold(Threshold);
// Double-check the "pulseSensor" object was created and "began" seeing a signal.
if (pulseSensor.begin()) {
Serial.println("We created a pulseSensor Object !"); //This prints one time at Arduino power-up, or on Arduino reset.
  int myBPM = pulseSensor.getBeatsPerMinute(); // Calls function on our pulseSensor object that returns BPM as an "int".
  // "myBPM" hold this BPM value now.
  if (pulseSensor.sawStartOfBeat()) { // Constantly test to see if "a beat happened".
    Serial.println("♥ A HeartBeat Happened ! "); // If test is "true", print a message "a heartbeat happened".
    Serial.print("BPM: "); // Print phrase "BPM: "
    Serial.println(myBPM); // Print the value inside of myBPM.
  servo1.write(0);  //min pulse width for 0 degree
  servo1.write(90);  //pulse width for 90 degree
  delay(20); // considered best practice in a simple sketch.
Although I do get pulse readings but the servo motor does not rotate. It jitters after each 2/3 sec. How can I achieve the execution of both sensors simultaneously, please?
The servo should have its own power supply, and only be controlled by the Arduino.. I suspect you are using the Arduino as a power supply.
Hmm I am using an external power supply module for that..
Post image of project.
Post schematic.
I guess there was certainly an issue with the circuit.. However, although I do get both of them working the servo motor jitters a lot. This is most probably because of the heart rate sensor because it works fine otherwise. Any idea how can I fix it please?
Post an image of the project.
Post a schematic.
motor jitter: power supply, running motors from a breadboard.
What do you think might be wrong?
The 1 amp power supply and power through a breadboard to a servo can cause the jitters.
Using this thing,
and words like "power servos" should get some results that may prove usefull.
If you remove the pulse sensor parts, does the servo sweep back and forth as expected?
ServoTimer2 servo1;
  servo1.attach(12);
Yes Sir
It seems like the PulseSensorPlayground library is somehow conflicting with the ServoTimer2 library. It has code to avoid a conflict with the Servo library so I would try that.
Change:
ServoTimer2 servo1;
to:
#include <Servo.h> // Must be before PulseSensorPlayground
Servo servo1;
Thank you Sir.
Actually, I also want to add software serial along with the servo motor and the pulse sensor. The SoftwareSerial use the same interrupt as the servo.h library. I also tried <AltSoftSerial.h> but I get the same issue. I actually want the baud rate of 115200 with another serial to be able to use the lidar sensor. (NeoSWSerial.h does not support baud rate of 115200)
The problem is that the interrupt handler of the servo, pulse sensor and serial does not working concurrently in ways I have tested so far.
I would truly appreciate any suggestions, please.
I would try turning off the PulseSensorPlayground interrupt.
#include <ServoTimer2.h> // Timer2
#include <SoftwarwSerial.h> // Timer1
#define USE_ARDUINO_INTERRUPTS false
#include <PulseSensorPlayground.h> // No Timer
ServoTimer2 servo1;
SoftwareSerial mySerial;
Hmm..
The pulse sensor works only if the PulseSensorPlayground interrupt is assigned true.
I can successfully compile the code and can get the readings of both the pulse sensor and lidar sensor but the servo motor jitters a lot. It does not rotate as expected :frowning:
ServoTimer2 servo1;
#include <SoftwareSerial.h> //header file of software serial port
SoftwareSerial Serial1(2,3);
// Variables
int dist2;
int i;
int uart[9]; //save data measured by LiDAR
const int HEADER=0x59; //frame header of data package
int check; //save check value
servo1.attach(12);
Serial1.begin(115200);
  for (int i = 0; i < 90; i++)
    lidar();
    servo1.write(i);
    delay(1);
  for (int i = 90; i > 0; i--)
    lidar();
    servo1.write(i);
    delay(1);
int lidar(){
  if (Serial1.available()) { //check if serial port has data input
     if(Serial1.read() == HEADER) { //assess data package frame header 0x59
      uart[0]=HEADER;
      if (Serial1.read() == HEADER) { //assess data package frame header 0x59
        uart[1] = HEADER;
        for (i = 2; i < 9; i++) { //save data in array
          uart[i] = Serial1.read();
      check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
      if (uart[8] == (check & 0xff)){ //verify the received data as per protocol
        dist2 = uart[2] + uart[3] * 256; //calculate distance value
    //    Serial.listen();
        Serial.print("lidar dist = ");
        Serial.println(dist2); //output measure distance value of LiDAR
        //Serial.print('\t');
        delay(100);
  return dist2;
Sir, grateful if you could please help me on this:
When I use the servo motor with pulse sensor, the latter gives reading although I am not touching it at all. Why is it so?
The code:
#include <Servo.h>
const int PulseWire = 0;       // 'S' Signal pin connected to A0
int distance;
PulseSensorPlayground pulseSensor;  // Creates an object
Servo servo;
long duration;
  servo.attach(12);
  servo.write(0);
  pulseSensor.blinkOnPulse(LED13);       // Blink on-board LED with heartbeat
  // Double-check the "pulseSensor" object was created and began seeing a signal
    Serial.println("PulseSensor object created!");
  int myBPM = pulseSensor.getBeatsPerMinute();      // Calculates BPM
  if (pulseSensor.sawStartOfBeat()) {               // Constantly test to see if a beat happened
    Serial.println("♥  A HeartBeat Happened ! "); // If true, print a message
    Serial.println(myBPM);                        // Print the BPM value
  delay(20);
  for (int i=0; i<180; i++){
      servo.write(i);
      //usdist();
      delay(5);
    for (int i=180; i>0; i--){
      servo.write(i);
      //usdist();
      delay(5);
