Servo motor
hi there,
I am having a problem driving a servo motor using ULN2003a chip. When i attach motor using attach function with digital pin 11 of my mega8, the motoe starts moving at a low speed while i have not given any command of rotation such as write function. Is attaching motor to a specific causes its rotation? What could be the problem?
Thanks in advance :slight_smile:
Did you modify this servo yourself? If so then you'll recall that you replaced the existing potentiometer with two resistors; the issue now is that those two resistors aren't perfectly balanced.
Instead of counting "90" as stationary you might need to use "89", "91", etc. until it stops.
Unless you have some weird setup, I think that isn't the way to control a servo.
ULN2003 is a darlington transistor pair which is a current amplifier and I think it can be used to drive servo motor. I have connected one pin of servo to VCC and the other to OUT1 of ULN and INPUT1 of ULN gets commands from pin 11 of mega8. I do not use any POT or Resistor for it. Is it weird to connect it like this? Do you have a better setup with/without ULN?
oops! I had a deep misunderstanding of difference between DC motors and servos! What I was doing was driving a DC motor using servo functions! I am going t buy a servo and test it. You were right, It was a weird setup :))
