Servo motors behaving erratically
I’m doing a small robot arm project using 4 micro servo motors connected to my arduino Uno, a breadboard and a 6v battery power supply. My arduino is connected separately to a USB and USB servos are powered from the 6v battery pack. I have followed a similar project that was available on the internet because I’m pretty new to arduino and stuff like this. I am controlling my servos via a bluetooth app on my android device which is working but the only issue I am experiencing is that my servos keep randomly moving and jittering rapidly and erratically even when I’m not controlling their movement. Could this be something to do with my code which I have provided below? I have also attached a circuit diagram.
Please post your code, in code tags
#include <Servo.h>  //arduino library
#include <math.h>   //standard c library
#define PI 3.141
Servo baseServo;
Servo shoulderServo;
Servo elbowServo;
Servo gripperServo;
int command;
struct jointAngle{
  int base;
  int shoulder;
  int elbow;
int desiredGrip;
int gripperPos;
int desiredDelay;
int servoSpeed = 15;
int ready = 0;
struct jointAngle desiredAngle; //desired angles of the servos
//+++++++++++++++FUNCTION DECLARATIONS+++++++++++++++++++++++++++
int servoParallelControl (int thePos, Servo theServo );
  baseServo.attach(9);        // attaches the servo on pin 9 to the servo object
  shoulderServo.attach(10);
  elbowServo.attach(11);
  gripperServo.attach(6);
  Serial.setTimeout(50);      //ensures the the arduino does not read serial for too long
  Serial.println("started");
  baseServo.write(90);        //intial positions of servos
  shoulderServo.write(150);
  elbowServo.write(110);
  ready = 0;
//primary arduino loop
  if (Serial.available()){
    ready = 1;
    desiredAngle.base = Serial.parseInt();
    desiredAngle.shoulder = Serial.parseInt();
    desiredAngle.elbow = Serial.parseInt();
    desiredGrip = Serial.parseInt();
    desiredDelay = Serial.parseInt();
    if(Serial.read() == '\n'){               // if the last byte is 'd' then stop reading and execute command 'd' stands for 'done'
        Serial.flush();                     //clear all other commands piled in the buffer
          //send completion of the command
        Serial.print('d');
  int status1 = 0;
  int status2 = 0;
  int status3 = 0;
  int status4 = 0;
  int done = 0 ;
  while(done == 0 && ready == 1){
    //move the servo to the desired position
    status1 = servoParallelControl(desiredAngle.base, baseServo, desiredDelay);
    status2 = servoParallelControl(desiredAngle.shoulder,  shoulderServo, desiredDelay);
    status3 = servoParallelControl(desiredAngle.elbow, elbowServo, desiredDelay);
    status4 = servoParallelControl(desiredGrip, gripperServo, desiredDelay);
    if (status1 == 1 & status2 == 1 & status3 == 1 & status4 == 1){
      done = 1;
  }// end of while
//++++++++++++++++++++++++++++++FUNCTION DEFITNITIONS++++++++++++++++++++++++++++++++++++++++++
int servoParallelControl (int thePos, Servo theServo, int theSpeed ){
    int startPos = theServo.read();        //read the current pos
    int newPos = startPos;
    //int theSpeed = speed;
    //define where the pos is with respect to the command
    // if the current position is less that the actual move up
    if (startPos < (thePos-5)){
       newPos = newPos + 1;
       theServo.write(newPos);
       delay(theSpeed);
       return 0;
   else if (newPos > (thePos + 5)){
      newPos = newPos - 1;
      delay(theSpeed);
      return 0;
    else {
        return 1;
I’m new to coding so it could be my program that’s causing the issue. Any help will be greatly appreciated
Joshy434:
Servos need a lot of current. Your symptoms are often caused because you're not providing it. Trying to push high current through a breadboard is questionable too.
Try some more basic code that just exercises the servos - leave the bluetooth stuff alone until they're working as expected.
 [code/]
flush works only on the tx buffer - look it up
check your line endings in the serial monitor!
Mark
