Hello,
First time with Arduino,
I'm building a robot for an academic project that should exercise (Push-Ups with 2 servo motors).
The process should be:
when clicking a button,
timer counts 5 seconds (timer display on LCD 1602 screen),
30 seconds of moving servo motors,
40 seconds of break
30 moving
40 break
30 moving
end of process
the timer should be always displayed on the lcd screen.
I know how to move the servo motor ("for" loop) and I know how to set a timer (every 1 second, reduce by one) but I don't know how to combine.
Note how each function runs very briefly and returns to loop() so the next one can be called. None of the functions tries to complete a task in one call. And there may be dozens of calls to a function before it is actually time for it to do anything.
I used this code and I would like to get some comments.
(I didn’t connect it to LCD screen yet so I only used serial.prinln to se the result:
#include <Servo.h>
Servo righthand; // right hand servo of the robot
Servo lefthand; // left hand servo of the robot
int pos = 0; // variable to store the servo position
unsigned long CurrentTime;
unsigned long PreviousTime = 0;
const unsigned long TimeInterval = 1000;
int NTimer = 6;
boolean ProcessEnd = false;
lefthand.attach(5); // attaches the servo on pin 5 to the servo object
righthand.attach(6); // attaches the servo on pin 6 to the servo object
lefthand.write(180); //initial position
righthand.write(90); //initial position
pinMode(2,INPUT);
void loop(){
if (digitalRead(2)==HIGH)
ProcessEnd = true;
if (ProcessEnd == true)
Serial.println ("Get Ready");
while (NTimer > 1)
CurrentTime = millis();
if (CurrentTime - PreviousTime >= TimeInterval) {
NTimer = NTimer - 1;
Serial.println (NTimer);
PreviousTime = CurrentTime;
for (int i=0; i<3; i++){
NTimer = 31; // Set exercise timer
Serial.println ("Start");
while (NTimer>0){
for (pos = 180; pos >= 90; pos -= 1) { // goes from 180 degrees to 90 degrees in steps of 1 degree
lefthand.write(pos); // tell servo to go to position in variable 'pos'
righthand.write(270-pos);
delay(15); // waits 15ms for the servo to reach the position
for (pos = 90; pos <= 180; pos += 1) { // goes from 90 degrees to 180 degrees
NTimer = 41; // Set break timer
Serial.println ("Take A Rest");
while (NTimer > 1)
Serial.println ("Excellent Job!");
ProcessEnd = false;
NTimer = 6;
