Servo Motors Move on their own- not being activated by capacitative touch sensor
#include <Servo.h>
// Variable Setup
int capValue[5];
int capSense[5];
int capThreshold;
int ledPins[5];
int testAngle;
int emojiToggle;
int emojiState;
int activeServos;
int servoDirection[4];
int servoAngle[4];
int armMin;
int armMax;
int analogIn;
Servo roboServo[4];
// Servo Setup
roboServo[0].attach(7); // Pin 7: fullServo
roboServo[1].attach(3); // Pin 3: handServo
//roboServo[2].attach(); // rotatorServo
//roboServo[3].attach(); // shoulderServo
for (int i=0;i<5;i++) {
servoDirection = 1; // (-'ve is opposite direction, can be increased if code changed below…)
  • activeServos = 1; //(+1)*
  • // Emoji State (and LEDS)*
  • emojiToggle = 0; // 0 = unpressed, 1 = pressed*
  • emojiState = 0; // loops after 4…*
  • capThreshold = 0;*
  • analogIn = 1; // Mode: analog or digital*
  • armMin = 20;*
  • armMax = 160;*
  • // Pin references*
  • if (analogIn) {*
  • capSense[0] = A0;*
  • capSense[1] = A1;*
  • capSense[2] = A2;*
  • capSense[3] = A3;*
  • capSense[4] = A4;*
  • } else {*
  • capSense[0] = 14;*
  • capSense[1] = 15;*
  • capSense[2] = 16;*
  • capSense[3] = 17;*
  • capSense[4] = 18;*
  • ledPins[0] = 6; //These are analog out pins (PWM)*
  • ledPins[1] = 9;*
  • ledPins[2] = 10;*
  • ledPins[3] = 11;*
  • ledPins[4] = 12;*
  • // Set up pin I/O*
  • for (int i=0;i<5;i++) {*
    _ pinMode(capSense*, INPUT);_
    _ pinMode(ledPins, OUTPUT);
    // Default Serial Value (9600)
    // Trigger LEDs with Capacitor Touch Values*
    * for (int i=0;i<5;i++) { // looping through all sensor inputs*
    * if (analogIn) { // Analog or digital read*
    capValue = analogRead(capSense*); // get value from capacitor sensor*
    capValue = map(capValue*, 0, 1023, 0, 255);*
    * } else {_
    capValue _= digitalRead(capSense);
    }*_
_ if (capValue > capThreshold) { // High recieved
* // Activate Emoji Toggle*
* if (i == 0) {*_
* // Should toggle-trigger a state change*
* if (emojiToggle == 0) {*
* emojiState++;*
* Serial.println(“Toggle Flag\n”);*
* if (emojiState >= 5) { // Loop Emoji State*
* emojiState = 0; *
* emojiToggle = 1;*
* } else if (i < activeServos) {*
* Serial.println(“Servo\n”);*
* // Flip Direction at Limits*
if ((servoAngle <= armMin && servoDirection == -1) || (servoAngle >= armMax && servoDirection == 1)) {
servoDirection _*= -1; _
* // Increment servo angle*
servoAngle += servoDirection*;*
* // Apply angle to servo*
roboServo_.write(servoAngle*);
// STUB: reverse direction on release?*_
* } else { // Low received*
* // Turn off toggle*
* if (emojiToggle == 1) {*
* emojiToggle = 0; *
* if (i == emojiState) { // Emoji Light*
* // Move to target angle for select emoji*
* int penta = 72;*
_ if (servoAngle[0] > emojiState * penta) {
* servoAngle[0]–;
} else if (servoAngle[0] < emojiState * penta) {
servoAngle[0]++;
} else if (servoAngle[0] == emojiState * penta) {
// drive LED*
* if (analogIn) {
analogWrite(ledPins[emojiState], capValue);
digitalWrite(ledPins[emojiState], HIGH);
}*_
* } else { // Unused LEDs*
* if (analogIn) {*
_ analogWrite(ledPins*, 0);
digitalWrite(ledPins, LOW);
}*_
Please edit your post to add code tags, after reading “How to use this forum”.
Most likely, your servo power supply is inadequate. Use a separate 5 to 6V regulated supply capable of providing 1 Ampere per servo, and don’t forget to connect the grounds.
Hi, Welcome to the forum.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code. It will be formatted in a scrolling window that makes it easier to read.
What are you using to power the servos.
Did you develop your code in stages? Have you got code that just controls ONE servo so you know your wiring is okay?
Thanks.. Tom... :)
