Servo motors, ultrasonic sensor, and/or code problem
Hello, so I'm making this project, a ultrasonic sensor that tracks the distance of the area nearby, and it's standing on top of a servo(1) which should always be rotating and when a object is closer than 20 cm, it turns on another servo(2), which makes an object fall(this servo just has to turn one time, amd then it can do whatever it wants :P). It's kind of an alarm. But I'm having problems with coding and I don't know if I'm doing things right with connecting servos and sensors to Arduino, so here's a scheme of the build and the code below, you're free to help me figuring the problem out, and btw, the problem is that none of the servos move or rotate, but the ultrasonic sensor calculates the distance, and even though an object is closer that 20 cm , it still doesn't turn on the servo(2). The ultrasonic sensor still measures the distance, but i'm not sure if the problem is with the sensor, my pins and connection , or to the motors, and btw, source of power i totally fine, but the servos won't turn on, and won't rotate, the code is fine too, i think at least, it doesn't give me any errors....
Here's the code:
#define ECHOPIN 7
#define TRIGPIN 8
#include <Servo.h>
float distance;
Servo servo;
int pos = 0; //
servo1.attach(9);
servo2.attach(3);
pinMode(7, OUTPUT);
pinMode(8, INPUT);
pinMode(ECHOPIN, INPUT);
pinMode(TRIGPIN, OUTPUT);
void Print (int R , int T)
Serial.print(R); Serial.print(", ");
Serial.print(T); Serial.println(".");
delay(100);
float Distance () {
digitalWrite(TRIGPIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIGPIN, HIGH);
delayMicroseconds(10);
float distance = pulseIn(ECHOPIN, HIGH);
distance = distance / 58;
return (distance);
servo1.write(45);
servo1.attach(9);
delay(400);
for (pos = 45; pos <= 45; pos += 1)
servo1.write(pos);
Print(Distance() , pos);
delay(10);
for (pos = 45; pos >= 45; pos -= 1)
servo1.write(pos); Print(Distance() , pos);
delay(10);
if (distance < 20)
servo2.attach(3);
servo2.write(45);
delay(400);
for (pos = 45; pos <= 45; pos += 45)
servo2.write(pos);
delay(10);
for (pos = 45; pos >= 45; pos -= 45)
servo2.write(pos);
delay(10);
Serial.print(distance);
Serial.println(" cm");
Here's a picture of my project!
i am also doing a project base on the same topic but i am not getting any solution. I have to store five different position in array in which ultrasonic distance will be stored along with the rotation of the servo motor from 0 to 180 degree.. can any one help me out with it...
Probably. But only if you post your code (in </> code tags) and say what it does and what you want it to do that's different.
Steve
