Hello guys!
I'm making a robotic arm that has 1 S90 microservo and 3 MG946R servos. The arduino is powered by a 9V/1A Power supply and the servos are powered by a stack of batteries to reach 6V.
The problem is that when I connect one servo directly to the arduino, if works as it should when compiling a simple test code. When I connect the servos on the breadboard, the servo only turns 30º to the left or so and completely stops.
I put a LED on the end of the breadboard to see continuity, and it stays on all the time and no dimming of the light, so I don't know what to do anymore.
Please help me on what I'm doing wrong.
I attached a photo of how I'm pluging it all, please refer to it.
#include <Servo.h>
Servo servo1;
void setup () {
servo1.attach(9);
void loop () {
servo1.write(30);
delay(300);
servo1.write(60);
delay(300);
Answer: Hooking a servo to a breadboard.
Look up how much current the breadboard can handle vs how much current the servo requires for proper operation.
Idahowalker:
Thanks for the quick reply.
The servos are rated for 500 to 900mAh, and since I'm powering it with 4 batteries rated for 2000mAh each, there is current to spare.
The servo does not work even when connecting directly with the batteries, so I guess the breadboard is not the bottleneck.
Where's the complete schematic of your setup?
Guys, I found what was wrong 5 minutes after I posted in here (and last night I searched the whole internet lol)
Turns out you need to connect the ground in the breadboard to the ground in the Arduino, and that's what I did wrong.
I appreciate the help of you all, thanks a lot!
Bkviegas:
You're confusing mA with mAh.
