Servo Motors
Hi, I am very new to electronics and was wondering if servo motors such as this one http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/servo/List/0/SortField/4/ProductID/102/Default.aspx would work with Arduino without a motor shield. If they would work, I would like to buy 3 to make an autonomous robot. Also, how would I connect them and are there any possible locations that sell them, because shipping from that store is really expensive and I'm on a tight budget.
Thanks, Jack
Servos can be used with the arduino (but need a seperate powersupply). Search the forum for servo to see hundreds of previous post to get up to speed on how they work.l with the arduino. Inexpensive servos can be ordered from sites like below.
http://www.hobbypartz.com/kahaoubrmo14.html
http://www.hobbyking.com/hobbycity/store/uh_viewItem.asp?idProduct=9549
Hi, Also look at:
http://xn--hgi.ws/YD-servos
These are already set up to run "Continuous Rotation" for Robot drive wheels. Check shipping prices for where you are...
DISCLAIMER: I mentioned stuff from my own Shop...
What is the differences between a continuous rotation servos and other servos?
Thank, Jack
http://www.google.com/search?q=continous+rotation+servo&hl=en&num=100&lr=&ft=i&cr=&safe=images&tbs=
One is a servo and one...isn't.
OK. I'm still confused. Would a regular servo work as a motor for a robot or would I need a continues rotation servo?
Thanks, Jack
It depends what you want the motor to do, and what compromises you're willing to make.
I want two motors to run two front wheel, being able to run at different speeds to allow turning, and be able to go backwards. And a third motor to turn a sensor or something. Jack
Wait. So can continuous rotation servos keep turning and turning and turning, but regular servos can only turn 360 and then stop?
Servos rarely manage 360 degrees. 180 or less is more normal.
But continues rotation servos can keep turning and turning? Also, how fast can they turn?
They're not servos, because they have lost their feedback mechanism. The fastest they can turn is the rating in their specification, usually specified in degrees per second.
I think I am going to purchase this motor: http://www.sparkfun.com/products/9347. If I use two of these:http://www.sparkfun.com/products/341 to power it how could I keep the voltage at 6 volts?
jag3498: I think I am going to purchase this motor: http://www.sparkfun.com/products/9347. If I use two of these:http://www.sparkfun.com/products/341 to power it how could I keep the voltage at 6 volts?
You're putting the cart before the horse.
For one thing, do you even know how much current one of those servos needs (running vs. stalled, as well), vs the mAh of the battery? If you don't understand this question, you'll probably end up with a robot that moves for about 5 minutes, then needs recharging.
In order to get 6 volts from a pair of those batteries, you would need some kind of voltage regulation scheme. In a pinch, a 7806 voltage regulator will do this, but you don't get much in the way of current output (about 1 amp - with a good heatsink); the 78xx family of regulators also aren't very efficient (and with such low battery mAh, you need as much efficiency as possible to extend your runtime). So now you're looking at a low voltage switching regulator (I know they make a 7805 equivalent form of these - so maybe a 7806 equiv also exists) - or building a buck converter, or something else.
Also - do you have a charger for those batteries - you can't just plug one of those up to anything to charge it (not unless you want a nice fire).
You'd be better off powering the servos from an 4-cell AA battery pack, running alkalines (for 6 volts) or NiMH (for 4.8 volts - or, if you can set up a 5-cell pack, you'll get 6 volts). This will give you the voltage you need, plus a greater mAh rating for longer run-time. You won't have to deal with voltage regulators, either. Run the Arduino off another pack separately...
