Working on a project to move a servo with an ultrasonic range finder (HC-SR04). I have movement, but it's repeated and I only want it to move once (from 00-1800-00). Any help is greatly appreciated. Thanks!
#define echoPin 7 // Echo Pin
#define trigPin 8 // Trigger Pin
#define LEDPin 13 // Onboard LED
#include <Servo.h>
Servo servo; // create servo object to control a servo
int pos =0;
int maximumRange = 100; // Maximum range needed
int minimumRange = 0; // Minimum range needed
long duration, distance; // Duration used to calculate distance
Serial.begin (9600);
servo.attach(2);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(LEDPin, OUTPUT); // Use LED indicator (if required)
/* The following trigPin/echoPin cycle is used to determine the
distance of the nearest object by bouncing soundwaves off of it. */
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
//Calculate the distance (in cm) based on the speed of sound.
distance = duration/58.2;
if (distance >= maximumRange || distance <= minimumRange){
/* Send a negative number to computer and Turn LED ON
to indicate "out of range" */
Serial.println("-1");
digitalWrite(LEDPin, LOW);
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
servo.write(pos); // tell servo to go to position in variable 'pos'
// waits 15ms for the servo to reach the position
for(pos = 99; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
delay (5); // waits 15ms for the servo to reach the position
else {
/* Send the distance to the computer using Serial protocol, and
turn LED OFF to indicate successful reading. */
Serial.println(distance);
digitalWrite(LEDPin, HIGH);
delay(5); // waits 15ms for the servo to reach the position
//Delay 50ms before next reading.
Your comments don't match your code. You say you are waiting for the servo to reach position, but you don't.
How do you know your servo will actually go to 180 ?
Why do you go to 180, and then start counting back down again, from 100 ?
You don't do anything while the servo is moving, so you why you tell it to move one degree at a time ?
And without any delay, you won't even accomplish one PWM cycle to the servo, before you start telling
it to go one degree more. Why not just tell it to go straight to 180, or zero, and let it go there ?
Dividing a long by a float, to get a long result, will probably work, but it is dodgy.
Your manipulation of Ledpin seems to be bogus.
You seem to have unecessarily duplicated the code, which makes unnecessary movements of the servo. It is not clear what your algorithm is actually trying to accomplish. Don't you want to point the servo in several different directions, and then use the ultrasound to see if anything is there ? Your code is always going to point the servo in direction 0, and then take a measurement there. Is that what you actually want to do ?
Yes, I am well aware of the looping that is the purpose of the loop() function. I am looking to interrupt the loop. I found a couple ways and haven't had a chance to try it. The use of the LEDPin informs me that the ping is working properly. The comments are where they need to be. I have the movement necessary, I just need to interrupt the loop.
Your insights have been helpful. I've changed things around a bit and I have the single movement I'm looking for but I can't get the board to reset to the specified conditions. Any suggestions?
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int resetPin = 12;
int pos = 0; // variable to store the servo position
int maximumRange = 10; // Maximum range needed
myservo.attach(9); // attaches the servo on pin 9 to the servo object
myservo.write(pos); // tell servo to go to position in variable 'pos'
digitalWrite(resetPin, LOW);
else {
digitalWrite(resetPin, HIGH);
Robin 2, Would you be able to give me an example? The only part of the comments that seem out of place to me is when the serial protocol is referred to. It's key to have the comments clear when asking for help.
Thanks
There are at least 4 examples in this. One of them probably results in the code not working as expected. With another, it's not clear whether the code would work better with the value in the comment. A third one will confuse the reader and a fourth one is just sloppy.
