Servo movement
Hey y'all,
Working on a project to move a servo with an ultrasonic range finder (HC-SR04). I have movement, but it's repeated and I only want it to move once (from 00-1800-00). Any help is greatly appreciated. Thanks!
#define echoPin 7 // Echo Pin
#define trigPin 8 // Trigger Pin
#define LEDPin 13 // Onboard LED
#include <Servo.h>
Servo servo;  // create servo object to control a servo
int pos =0;
int maximumRange = 100; // Maximum range needed
int minimumRange = 0; // Minimum range needed
long duration, distance; // Duration used to calculate distance
 Serial.begin (9600);
 servo.attach(2);
 pinMode(trigPin, OUTPUT);
 pinMode(echoPin, INPUT);
 pinMode(LEDPin, OUTPUT); // Use LED indicator (if required)
/* The following trigPin/echoPin cycle is used to determine the
 distance of the nearest object by bouncing soundwaves off of it. */
 digitalWrite(trigPin, LOW);
 delayMicroseconds(2);
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(10);
 duration = pulseIn(echoPin, HIGH);
 //Calculate the distance (in cm) based on the speed of sound.
 distance = duration/58.2;
 if (distance >= maximumRange || distance <= minimumRange){
 /* Send a negative number to computer and Turn LED ON
 to indicate "out of range" */
 Serial.println("-1");
 digitalWrite(LEDPin, LOW);
 for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
   {                                // in steps of 1 degree
     servo.write(pos);              // tell servo to go to position in variable 'pos'
                                    // waits 15ms for the servo to reach the position
   for(pos = 99; pos>=1; pos-=1)    // goes from 180 degrees to 0 degrees
     delay (5);                     // waits 15ms for the servo to reach the position
 else {
 /* Send the distance to the computer using Serial protocol, and
 turn LED OFF to indicate successful reading. */
 Serial.println(distance);
 digitalWrite(LEDPin, HIGH);
     delay(5);                     // waits 15ms for the servo to reach the position
 //Delay 50ms before next reading.
Once under what conditions? If you don't want something done over and over, don't put code to do it in loop().
