Servo Movement
I’ve having some trouble, i want to get a servo to move just 90 degrees, slowly, back and forth. Every tutorial i’ve tried makes the servo go a full rotation, how can i change that?
. Every tutorial i've tried makes the servo go a full rotation, how can i change that?
R/C servos rarely make a full rotation - they have mechanical stops which prevent this.
What code have you been using?
im assuming you mean a real servo, not continuous?
look at the lines: #define time 15
#define PosGoal 90
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
#define time 15 //CHANGE THIS for how fast the servo moves from pos to pos, in miliseconds
#define PosGoal 90 //change this to the angle you want to go to
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  myservo.write(0);
  for(pos = 0; pos < PosGoal; pos += 1)  // goes from 0 degrees to 90 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(time);                       // waits 15ms for the servo to reach the position
  for(pos = PosGoal; pos>=1; pos-=1)     // goes from 90 degrees to 0 degrees
