Hi there
i'm trying to control a 300deg servo with an arduino and it is working perfectly, except for one wee glitch. the servo is a 300 deg, and i need it to turn a full 180, so i have the home position at 1750 and the 180 position is at 500 (min extent counter clockwise) when i boot the arduino it seems that in the setup when the servo is attached, it goes to centre (1500) when it gets to line 52 (the attached code doesn't show the line numbers, but it's myservo.writeMicroseconds(DAMPER_CLOSE_DEGREES); after myservo.attach) it sets it to 1750, the desired home position. i don't want the servo to move when i boot if it can be helped. i won't boot it often, only when we have power cuts, but still, it would be nice.
#include <Servo.h>
#include <Arduino.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
#define SERVO_POSITION A0
#define DRYER_INPUT 2
#define SERVO_POWER 3
#define GREEN_LED 4
#define RED_LED 5
#define SERVO_PIN 9
#define DAMPER_IS_OPENED 0
#define DAMPER_IS_CLOSED 1
#define DAMPER_CLOSE_DEGREES 1750
#define DAMPER_CLOSE_POSITION 397
#define DAMPER_OPEN_DEGREES 500
#define DAMPER_OPEN_POSITION 982
#define SERVO_POSITION_PERMITTED_ERROR 10
#define ONE_SECOND 1000
#define TEST_FOR_POSITIONING_ERROR(pos) if( abs(pos - val) > SERVO_POSITION_PERMITTED_ERROR ) digitalWrite(RED_LED, HIGH)
int angle = 0; // variable to store the servo position
int val;
int DAMPERPosition = DAMPER_IS_CLOSED;
pinMode(SERVO_POSITION, INPUT); // position of the servo feedback
pinMode(DRYER_INPUT, INPUT); // input from sensor about dryer on
pinMode(SERVO_POWER, OUTPUT);
pinMode(GREEN_LED, OUTPUT);
pinMode(RED_LED, OUTPUT);
digitalWrite(RED_LED, LOW);
digitalWrite(GREEN_LED, LOW);
myservo.attach(SERVO_PIN); // attaches the servo on pin 9 to the servo object
digitalWrite(SERVO_POWER, HIGH); // turn servo power supply on
delay(ONE_SECOND);
myservo.writeMicroseconds(DAMPER_CLOSE_DEGREES); // make sure DAMPER is closed when we power up
val = analogRead(SERVO_POSITION);
Serial.print("Power"); //doesn't print
Serial.println(val);
//TEST_FOR_POSITIONING_ERROR( DAMPER_CLOSE_POSITION );
delay(ONE_SECOND);
digitalWrite(SERVO_POWER, LOW); // turn servo power supply off
int dryerSensor = analogRead(DRYER_INPUT);
Serial.print("Dryer ");
Serial.println(dryerSensor);
if(dryerSensor >= 100 )
if( DAMPERPosition == DAMPER_IS_CLOSED )
myservo.writeMicroseconds(DAMPER_OPEN_DEGREES);
delay(ONE_SECOND);
Serial.print("OPEN ");
TEST_FOR_POSITIONING_ERROR( DAMPER_OPEN_POSITION );
DAMPERPosition = DAMPER_IS_OPENED;
digitalWrite(GREEN_LED, HIGH);
if( DAMPERPosition == DAMPER_IS_OPENED )
delay(ONE_SECOND);
Serial.print("CLOSE ");
delay(300);
