Servo moving erratically from external power source
I created my own external 7v power source (tested stable using a multimeter). When I connect the servo to the 5v Arduino power pin, everything works, but when I connect it to my custom 7v power source, the servo moves erratically, which doesn't make any sense to me... The code is nothing special:
#include <Servo.h>
const int servo_pin=9;
Servo servo;
  servo.attach(servo_pin);
  Serial.println("hello");
  servo.write(90);
  Serial.println(servo.read());
  servo.write(180);
I am using the Adafruit Metro 328 board
Did you connect the ground together ? If not, see FAQ: How to use two power supplies. - Introductory Tutorials - Arduino Forum
Is the servo intended to run on 7V? Most small servos are only rated for 6V.
What exactly is your "7V power source"? A multimeter smooths out readings so it won't tell you if it is truly stable. It could have terrible ripple or spiking and a multimeter would never notice.
Steve
IoT_hobbyist:
I did not connect my 7v power supply to the arduino. I powered my arduino board using an usb connection to my pc. Only the signal pin of the servo is connected to the arduino.
Claire_Redfield:
Then you need to connect the negative of your "power source" to the Arduino GND. Without that it doesn't have a reference for the signal.
Steve
slipstick:
Steve
Thanks! It works now
