Servo newbie needs help
hi,
I’m trying to make a servo rotate continuously so I used this code.
  for(pos = 0; pos < 360; pos += 1)
    myservo.write(pos);
    delay(15);
When it reaches 360, it changes direction back to zero. It’s sweeping back and forth. How do I make it keep spinning continuously?
Thanks.
oh, ok http://www.sparkfun.com/datasheets/Robotics/servo-360_e.pdf
model: SM-S4303R
When it reaches 360, it changes direction back to zero. It's sweeping back and forth. How do I make it keep spinning continuously?
You would have to modify your servo into a "continous rotation" servo. Once it is modified, it will lose it's capability to be positioned in a specific location. You might be better off getting another inexpensive servo and modifying it (like below), or buying a servo that is already modified for continous rotation.
http://www.lynxmotion.net/viewtopic.php?f=31&t=6388
I finally found some code help on through sparkfun http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1278145608
this servo does spin continuously but can't address what angle the shaft so my code was all wrong.
I should have just send in a wavelength
myservo.writeMicroseconds(i);
and it will spin at a certain speed & direction.
