Hi, I decided to have a go at servo noise on some cheap plastic SG90s.
TBH I haven't breadboarded this even, I just jump straight into KiCAD as I've just received some photo sensitive PCBs today.
It does not hurt to put a 0.1uF cap in parallel with the 10/100uF caps on the servo supply rails. The higher value caps (10/100) are good for supplying a bit of extra current when the load changes (low frequencies). The low value caps (0.1) are good for shunting higher frequency noise (ie. motor brush noise) to ground.
