I am working on a project where I have to close a window with a servo when the CO2 value is too high. When the servo opens it has enough power and it stays in this position but when the servo closes it doesn't give enough power and it won't stay in position. Anyone have an idea?
#include "SCD30.h"
#include <Servo.h>
Servo myservo;
#if defined(ARDUINO_ARCH_AVR)
#pragma message("Defined architecture for ARDUINO_ARCH_AVR.")
#define SERIAL Serial
#elif defined(ARDUINO_ARCH_SAM)
#pragma message("Defined architecture for ARDUINO_ARCH_SAM.")
#define SERIAL SerialUSB
#elif defined(ARDUINO_ARCH_SAMD)
#pragma message("Defined architecture for ARDUINO_ARCH_SAMD.")
#elif defined(ARDUINO_ARCH_STM32F4)
#pragma message("Defined architecture for ARDUINO_ARCH_STM32F4.")
#else
#pragma message("Not found any architecture.")
#endif
#include <Wire.h>
#include "rgb_lcd.h"
// KNOPPEN
const int automatisch = 6;
const int manueel = 5;// the number of the pushbutton pin
const int opentoeknop = 2;
byte openen = HIGH;
byte sluiten = LOW;
//LEDS
const int ledPinBlauw = 4;
const int ledPinGroen = 3;
// LCD scherm
rgb_lcd lcd;
const int colorR = 50;
const int colorG = 140;
const int colorB = 0;
// variablen
int ppmmax = 900;
int joeri = 0;
int buttonState = 0;
int buttonState1 = 0;
int buttonState2 = 0;
int lastButtonState = 0;
int buttonPushCounter = 0;
int pos = 0;
int waarde=0;
int servohoek=0;
// initialize the LED pin as an output:
pinMode(ledPinGroen, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(automatisch, INPUT);
pinMode(manueel, INPUT);
pinMode(opentoeknop, INPUT);
pinMode(ledPinBlauw, OUTPUT);
digitalWrite(ledPinBlauw, LOW);
digitalWrite(ledPinGroen, LOW);
lcd.begin(16, 2);
lcd.setRGB(colorR, colorG, colorB);
lcd.setCursor(0, 0);
lcd.print("A: Automatisch");
lcd.setCursor(0, 1);
lcd.print("B: Manueel");
Wire.begin();
SERIAL.begin(115200);
SERIAL.println("SCD30 Raw Data");
scd30.initialize();
myservo.attach(8);
while (joeri == 0) {
buttonState = digitalRead(automatisch);
buttonState1 = digitalRead(manueel);
if (buttonState == HIGH) {
// turn LED on:
lcd.print("U kiest voor ");
lcd.print("automatisch ");
joeri = joeri + 1;
delay(2000);
digitalWrite(ledPinGroen, HIGH);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState1 == HIGH) {
// turn LED on:
lcd.print("manueel ");
joeri = joeri + 1;
delay(2000);
while (joeri >= 1) {
float result[3] = {0};
while (buttonState == HIGH) {
scd30.getCarbonDioxideConcentration(result);
SERIAL.print("Carbon Dioxide Concentration is: ");
SERIAL.print(result[0]);
SERIAL.println(" ppm");
SERIAL.println(" ");
SERIAL.print("Temperature = ");
SERIAL.print(result[1]);
SERIAL.println(" ℃");
SERIAL.print("Humidity = ");
SERIAL.print(result[2]);
SERIAL.println(" %");
lcd.print("CO2: ");
lcd.print(result[0]);
lcd.print(" ppm");
lcd.print("Temp: ");
lcd.print(result[1]);
lcd.print(" C");
buttonState = HIGH;
delay(5000);
while (result[0] >= ppmmax) {
lcd.print("CO2: ");
lcd.print(" ppm");
lcd.print(" C");
if (servohoek == 0) {
for (pos = 0; pos <= 45; pos += 1) {
// goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15);
servohoek=90;
Serial.println("open");
digitalWrite(ledPinBlauw, HIGH);
delay(5000);
lcd.print("CO2: ");
lcd.print(" ppm");
lcd.print(" C");
if (servohoek == 90) {
for (pos = 45; pos >= 0; pos -= 1) {
myservo.write(pos);
delay(15);
servohoek=0;
Serial.println("toe");
delay(5000);
while (buttonState1 == HIGH) {
buttonState2 = digitalRead(automatisch);
// compare the buttonState to its previous state
if (buttonState2 != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState2 == HIGH) {
// if the current state is HIGH then the button went from off to on:
buttonPushCounter++;
Serial.println("on");
Serial.print("number of button pushes: ");
Serial.println(buttonPushCounter);
// if the current state is LOW then the button went from on to off:
Serial.println("off");
// Delay a little bit to avoid bouncing
delay(50);
lastButtonState = buttonState2;
if (buttonPushCounter % 2 == 0) {
for (pos = 0; pos <= 90; pos += 1) {
delay(15);
servohoek=90;
else {
lcd.print("CO2: ");
lcd.print(" ppm");
lcd.print(" C");
delay(2000);
else {
for (pos = 90; pos >= 0; pos -= 1) {
myservo.write(pos);
delay(15);
servohoek=0;
else {
digitalWrite(ledPinBlauw,LOW);
lcd.print("CO2: ");
lcd.print(" ppm");
lcd.print(" C");
delay(2000);
