Servo Not working
I am building a remote controlled mouse trap that will be loaded with airsoft BBs. I have a RF Key fob and receiver. I just need a code that will make the servo rotate 90 degrees when the button goes high, then -90 degrees when it goes low. This is the code I have now. COuld someone please revise it?
#include <Servo.h>
Servo myservo;
int buttonPin = 2;
int pos = 0;
  myservo.attach(9);
  pinMode(buttonPin, INPUT); // attaches the servo on pin 9 to the servo object
void loop(){
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH);
    (pos = 90);{
  if (buttonState == LOW);
    (pos = 0);
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
I won't revise it - I'll leave that to you; however, I will give you a clue - braces.
have you wired everything properly?
Too many semicolons.
Do you get errors when you try to compile the code?
if (buttonState == HIGH)[glow];[/glow]
