Servo position value, can it be real number?
As the topic says, can a value of a Servo position be a real number like 43.5 and not integer??
myservo.write(43.5);
I didn't know where to post this question, whether here or at "motors" part of the arduino forum. Thanks!
No. A floating point argument will simply be truncated.
thanks!
If you need finer control, you can use the writeMicroseconds method. However, asking for fractional degree accuracy of an R/C servo may be asking a bit much.
You might add 0.5 to get proper rounding
float angle = 43.4; myservo.write(angle + 0.5); ==> 43 degrees
float angle = 43.6; myservo.write(angle + 0.5); ==> 44 degrees
Thanks guys.
