Hi , Im having some problems with my modified servo and I think its because the potentiometer its not centered ,the problem is that its already glued. Please , can someone help me fix that cause I cant get a new one quick and I need it. Any solution?-
If the pot is way too much in one direction to calibrate, you might replace the pot with two resistors as the voltage divider. This is commonly done (assuming you can easily remove/disconnect the pot).
