Ok, so I'm having a bit of a rough time with this final part of my project, I'm building an R2D2. I have EVERYTHING running except for the servo that turns R2's head. I have written test code 3 different ways, and all three ways have worked -rewrote Adafruits Motor Party(stripped it down to just the for loops and servo bit), and 2 simple sketches that use .write() or .writeMicroseconds(). I have even gone so far as to copy my test code verbatim into my current R2 sketch... and still no dice.
If anyone can help, I would greatly appreciate it.
Here is the current R2 code:
Author:
Matt Tucker
Date:
27APR2018
Description:
The combination of several individual test projects. The following code will test:
4 LEDs, 2 motors, 1 servo, and 1 speaker
The code is to be executed on a Mega 2560 with a motor shield and sensor shield.
Notes:
Future iterations will include a Raspberry Pi running a Python script that communicates
with the Mega 2560. The Python script will use OpenCV to evaluate images from a live
video for faces, dogs, ect and then send commands to the Mega 2560 accordingly.
//***Speaker***
#include <SD.h>
#define SDPIN 53
#include <TMRpcm.h>
TMRpcm tmrpcm;
int i = 0;
String file;
String type = ".wav";
//********END*****//
//***UltraSonic***
const int pingPin = A4;
//***LEDs***
const int ledPin1 = 34;
const int ledPin2 = 36;
const int ledPin3 = 38;
const int ledPin4 = 40;
//***Motors***
#include <AFMotor.h>
AF_DCMotor motor1(2);
AF_DCMotor motor2(3);
//***Servo***
#include <Servo.h>
Servo servo1;
const int servoPin = 9;
//***GeneralGlobalVariables***
#include <math.h>
int rndNum;
int count = 0;
randomSeed(analogRead(0));
//***Speaker***
tmrpcm.speakerPin = 46;
tmrpcm.setVolume(5);
if (!SD.begin(SDPIN))
Serial.println("Initialization Failed!");
return;
//***Servo***
servo1.attach(servoPin);
//***Motors***
motor1.setSpeed(255);
motor2.setSpeed(255);
motor1.run(RELEASE);
motor2.run(RELEASE);
//***LEDs***
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
pinMode(ledPin4, OUTPUT);
//***StartUP***
//tmrpcm.play("60.wav");
digitalWrite(ledPin1, HIGH);
digitalWrite(ledPin2, HIGH);
digitalWrite(ledPin3, HIGH);
digitalWrite(ledPin4, HIGH);
//delay(10000);
delay(100);
//***Motors***
void Forward()
motor1.run(FORWARD);
motor2.run(FORWARD);
delay(2000);
void VearLeft()
motor1.setSpeed(200);
motor2.setSpeed(100);
delay(2000);
void VearRight()
motor1.setSpeed(100);
motor2.setSpeed(200);
delay(2000);
void TurnLeft()
motor2.run(BACKWARD);
delay(2000);
void TurnRight()
motor1.run(BACKWARD);
delay(2000);
void Backward(long inches)
while (inches <= 6)
void Backward()
delay(2000);
void RevLeft()
delay(2000);
void RevRight()
delay(2000);
void Coast()
void Stop()
motor1.run(BRAKE);
motor2.run(BRAKE);
//***Servo***
void Servo_Motor_Turn()
servo1.writeMicroseconds(2000);
servo1.writeMicroseconds(1500);
servo1.writeMicroseconds(1000);
void Servo_Motor_UnTurn()
//***UltraSonic***
long Sensor_loop()
long microseconds, inches;
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
pinMode(pingPin, INPUT);
microseconds = pulseIn(pingPin, HIGH);
//code to convert time to distance
inches = long (microseconds / 74 / 2);
//code to print distance values
Serial.print(inches);
Serial.print("in, ");
return inches;
delay(100);
//***LEDs***
void Blink1(int num)
num = (num % 20) * 100;
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
delay(num);
digitalWrite(ledPin3, LOW);
digitalWrite(ledPin4, LOW);
delay(num);
delay(num);
void Blink2(int num)
delay(num);
delay(num);
void Blink3(int num)
delay(num);
delay(num);
//***SPEAKER***
void Speaker()
file = String((i % 62) + 2) + ".wav";
Serial.println("playing: " + file);
tmrpcm.play(file.c_str());
i++;
rndNum = random(0, 100);
//ALL***UltraSonic_Motors_Servo_Speaker_LEDs***ALL
Serial.println("Count: " + String(count));
long inches = Sensor_loop();
if (inches > 6)
Forward();
Blink3(rndNum);
Serial.println("Speaker");
Speaker();
Serial.println("ServoTurn");
Servo_Motor_Turn();
Serial.println("Stop");
Stop();
Serial.println("blink1");
Blink1(rndNum);
Serial.println("backward");
Backward();
Serial.println("stop");
Stop();
Serial.println("blink2");
Blink2(rndNum);
count++;
Here is the last test code I wrote/tested succesfully:
#include <Servo.h>
Servo servo1;
Servo_Motor_Turn();
