Servo Problem
hi everyone ^^
I have this servo : TGY-SM-4309R
and i used this sketch in arduino uno just to test if my servo is working or no,
ps: I linked the between the servo and arduino directly without any regulator or resistor... so linked GND of TGY-SM-4309R with GND of arduino. Vcc Of TGY-SM-4309R with 3,3V pin and the control to the Pin 9 of arduino ( i attached a picture to show the way i linked arduino with that Servo)
this is the sketch i uploaded in the arduino:
#include <Servo.h>
int servoPin = 9;
Servo tgyServo;
tgyServo.attach(servoPin);
for (int i = 0; i <=360; i=i+20)
tgyServo.write(i);
and the result is this: servo directly controled by Arduino. (problem) - YouTube
Can someone tell me where is the problem???
I can't see the video, but your diagram shows you're powering the servo from the Arduino.
Don't do that.
AWOL:
Don't do that.
Beat me to it, so my contribution is the pic below.
What results did you expect? That device is clearly not a servo, so expecting it to behave like one is unrealistic.
I think the definition of 360 degree servo is not clear and unambiguous - The rotation angle should be defined under the frame work of PWM range, i.e. a protocol of communication.
For the servo prom OP has, it seems like it is a continuous rotate servo, or called it geared motor /ESC with servo horn to be more precise. All you need to power it is a pwm very close around 1.5ms should control it to turn or stop. Which is useful to some application.
I bought a few 180dgree, and 360 degree servo from ebay, and under RC receiver pulse 1-2ms, they all just rotate 60 degree only, I guess they would turn 180 or 360 under arduino signal 0-2ms. wider than Rc PWM. But I need to buy some continuous turn and some true 180/360 under RC pwm.
