Hello,
i cant get my servo to run. When i take the section of code out of my program and just upload that, it runs just fine. However when i run the actually program, the LEDs blink just fine and my if statements works.
i am powering the servo externally because i knew that was an issue.
Now im just stuck
thanks in advance!!
#include <Servo.h>
Servo servo;
const int MaxNum = 3; // number times beam can be tripped
const int LEDPIN = 6; // Red LED
const int LEDPIN2 = 8; // Green LED
const int SENSORPIN = 4; // Servo Pin
const int RTime = 150; // delay time for Red LED
const int GTime = 150; // delay time for Green LED
const int Stime = 500; // delay time for Servo
const int Angle = 80; // max angle Servo moves
int sensorState = 0; // variable for reading the pushbutton status
servo.attach(2);
pinMode(LEDPIN2, OUTPUT);
pinMode(LEDPIN, OUTPUT);
pinMode(SENSORPIN, INPUT);
digitalWrite(SENSORPIN, HIGH);
int count = 0;
sensorState = digitalRead(SENSORPIN); // check if the sensor beam is broken
if (count < MaxNum) {
digitalWrite(LEDPIN2, HIGH);
if (sensorState == LOW) { //when beam is broken
for (int x = 0; x <= 5; x ++) { // loop for LED.
delay(GTime);
digitalWrite(LEDPIN2, LOW);
delay(GTime);
// runs Servo motor.
for (int pos = 55; pos < Angle; pos++) {
servo.write(pos);
for (int pos = Angle; pos > 55; pos--) {
servo.write(pos);
count++;
else { // if beam is detected
servo.write(55);
} else if (count == MaxNum) { // if the max count has been reached
digitalWrite(LEDPIN, HIGH);
