Servo problems
I’m integrating an Arduino into a system that uses a Battle Switch relay that is used to control a solenoid. I was told from the manufacturer that the switch uses standard servo pulses for each of the following:
–Trip point: 1500us
–Hysteresis: 40us
Recommended Values:
–Off: 1300us
–On: 1700us
Unfortunately, this is my first time using servo commands, and I’m unsure how to control this switch. Below is the code I’ve used.
#include <Servo.h>
int Hservo = 5;        //PWM
int Vservo = 3;        //PWM
int pumpOut = 4;
int horizontal = 8;    //input from joystick
int vertical = 9;      //input from joystick
int i, threshold = 500, pulseDif = 35;
long vals, average, prevAverage;
//int pump = 1;
int Y, X;
Servo BattleSwitch;
  pinMode(Hservo, OUTPUT);
  pinMode(Vservo, OUTPUT);
  BattleSwitch.attach(pumpOut);
  BattleSwitch.writeMicroseconds(1700);
  X = analogRead(horizontal);
  Y = analogRead(vertical);
  X = map(X, 0, 1023, 125, 254);
  Y = map(Y, 0, 1023, 125, 254);
  analogWrite(Hservo, X);
  analogWrite(Vservo, Y);
  //  if ((millis() % 5000) == 0) {
  //    if (pump == 1) {
  //      pump = 0;
  //    else {
  //      pump = 1;
  //Turn on solenoid
//    if (pump == 1) {
//      BattleSwitch.writeMicroseconds(1700);
//    else if (pump == 0) {
//      BattleSwitch.writeMicroseconds(1300);
  //Reading FSRs
  for (i=0; i<500; i++) {
    vals += analogRead(9);
    if (i == 499) {
      average = vals/500;
      if (((average - pulseDif) > prevAverage) && (average < threshold)) {
        Serial.print("          ");
        Serial.println(average);
      else{
      prevAverage = average;
      vals = 0;
      delay(250);
  delay(50);
The commented out parts were other approaches I tried. With all methods, the battle switch worked fine for a few seconds, and then the system started “twitching”. As you can see from the code, I have two PWM outputs to control a horizontal and vertical servo (I found that method from trial and error). Anyway, what I mean by twitching is that the horizontal and vertical servos started moving without any changing input from the joystick controlling them.
Any suggestions? Like I said, I’ve never used servo code before, so I don’t know how to use it, so any comments would be much appreciated.
Also, if someone could explain what Hysteresis and trip point mean, I'd be grateful!
So why are you using PWM instead of the servo libraries?
The battle switch specifically states that it uses servo pulses. A couple of weeks ago, through trials and measurements, I found that the servos used in vertical and horizontal movement operated when sent a PWM signal. Certain values correspond to certain positions.
Standard servo pulses have a repetition rate of 50Hz, and a typical duty-cycle of less than 10%.
Arduino PWM runs closer to 500Hz.
At this rate, your maximum pulse length is a shade under 2ms.
How are you powering all this?
Can you provide a link to the spec of the device?
The horizontal and vertical servos: http://www.servocity.com/html/heavy_duty_linear_servo__25__l.html The battle switch: http://www.dimensionengineering.com/BattleSwitch.htm As far as powering the system, I'm using 2 18V Makita batteries and a DC to DC converter.
After reading the information about servo pulses and PWM frequency discrepancies, I went ahead and altered my code controlling the horiz. and vert. servos based on the values given on the website:
  X = map(X, 0, 1023, 2000, 1000);
  Y = map(Y, 0, 1023, 2000, 1000);
  HServo.writeMicroseconds(X);
  VServo.writeMicroseconds(Y);
Now, my biggest problem is the twitching/temporary freezing of the system. How often am I supposed to call the .writeMicroseconds()?
It shouldn't matter - the update rate will be limited by the frame rate of the library.
Do you have any ideas as to why the board might freeze while doing this? I guess the board might not actually be frozen, but the joystick is temporarily disabled and none of the servos work and the Battle Switch opens.
No idea, without seeing a circuit.
Make sure you’ve got adequate decoupling and debug prints.
This:
    if (i == 499) {
strikes me as an odd construction - why not just wait for the end of the loop?
Well, I’ve done serial prints after everything, and traced the output and it all seems to be fine. The sketch I just tested was:
#include <Servo.h>
int pumpOut = 4;
int FSR_R = 12;        //input from FSR in right leg
int pump = 1;
int Y, X;
Servo HServo, VServo;
Servo BattleSwitch;
  Serial.println("Battle Switch setup complete");
  HServo.attach(Hservo);
  Serial.println("HServo setup complete");
  VServo.attach(Vservo);
  Serial.println("VServo setup complete");
  Serial.println("X reading complete");
  Serial.println("Y reading complete");
  Serial.println("X mapping complete");
  Serial.println("Y mapping complete");
  Serial.println("HServo write complete");
  Serial.println("VServo write complete");
  Serial.println("Battle Switch write complete");
What do you mean by decoupling?
