Servo programing help.
Hi! Can you please help me with my code? I attach a copy below.
I want to generate a random sweep for four servo connected to 5,6,9 and 10, the problem I have is I don’t know enough about the code to figure out where I have gone wrong. Same old story, I have taken the standard code from the examples “sweep” and tried to add a second servo using a random position genorator.
How would it be with four servo?
I would appreciate some advice with the following case and if you can help me to understand where I went wrong I should not make the same mistake next time :slight_smile: (probably!)
Thanks in advance.
Kind regards
Björn
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
#include <Servo.h>
Servo xservo; // create servo object to control a servo
Servo yservo; // a maximum of eight servo objects can be created
int xpos = 0; // variable to store the servo position
int ypos;
int ynew;
xservo.attach(9); // attaches the servo on pin 9 to the servo object
yservo.attach(10);
ypos = random(180);
#define change(a,b) if (a>b) a--; else (a
for(xpos = 0; xpos < 180; xpos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
xservo.write(xpos); // tell servo to go to position in variable 'pos'
delay(10); // waits 15ms for the servo to reach the position
for(xpos = 180; xpos>=1; xpos-=1) // goes from 180 degrees to 0 degrees
ynew = random(180);
while ((ypos != ynew))
change(ypos,ynew)
yservo.write(ypos);
delay (10);
This does not look right, but I can't figure what you would like it to do
ynew = random(180);
 change(ypos,ynew)
 yservo.write(ypos);
 delay (10);
If you just want it to go to a new random position each time through loop() you just need
ynew = random(180);
 yservo.write(ynew);
 delay (10);
...R
change(ypos,ynew)
What is happening here?
This can’t possibly be right, but I can’t figure out what it was meant to do.
Why don’t you just write the if statement where you want it instead of trying to use a macro here. Or write a function. Macros that do code can cause all sorts of headaches if you don’t know what you’re doing.
if(ypos > ynew)
     ypos--;
     ypos++;
yservo.write(ypos);
delay (10);
In addition to what the others said, look at this code for moving many servos http://forum.arduino.cc/index.php?topic=59530.msg430572#msg430572 (read the whole thread) and here is the result : http://vimeo.com/24959129#
