Servo Programming Help
Hello, I am making a programmable airsoft target with a servo motor. I’ve included my code, as you can see, I initialize 2 buttons, but am only using 1. The first button initiates the While loop and loops the target program, what I would like to do is have the second button break this loop, can anyone give me input on how to do that? Initiating an IF statement in the loop then using the break command doesn’t seem to work. The code I have so far works with Button 1, I know my setup is correct because the buttons both work with other types of codes. I am new to Arduino Programming so let me know If I’m an idiot or making a trivial mistake. Thanks :slight_smile:
Here is my code:
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int buttonState = 0; // variable for reading the pushbutton status
int buttonState2 = 0; // variable for reading the pushbutton status
const int buttonPin = 2; // the number of the pushbutton pin
const int buttonPin2 = 3; // the number of the pushbutton pin
myservo.attach( 8 ); // attaches the servo on pin 8 to the servo object
pinMode(buttonPin, INPUT_PULLUP);
pinMode(buttonPin2, INPUT_PULLUP);
buttonState = digitalRead(buttonPin);
buttonState2 = digitalRead(buttonPin2);
while (buttonState == LOW) {
myservo.write(173); // tell target to go to position not viewable
randomSeed(millis()); //specifies unit for time function
delay(random(3000,10000)); //delays a random time between 3 and 10 seconds
myservo.write(97); // target goes to viewable position
delay(4000); // target stays in position for certain amount of time
Get rid of the delay()s and use millis() for timing. During the delay() nothing else happens, including reading inputs.
Look at Using millis() for timing. A beginners guide, Several things at the same time and look at the BlinkWithoutDelay example in the IDE.
If you ever do press the switch, you are f**ked, as this while loop has NO way of ending.
The randomSeed() function should be called ONCE, in setup(), NOT in loop(), and not over and over.
If you want to break out of this while loop if a switch is (or becomes) pressed, feel free to actually read the state of the switch in the loop.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks… Tom… :slight_smile:
