Hello to everyone! I am new and i am trying to make a rfid lock
Rfid and servo works but separately(not in the same sketch.
Sorry for my bad english
Servo:MG90S
Rfid:RC522
I am using arduino leonardo
I am powering the servo with a driver
I am getting that when i scan the rfid card,but servo does nothing:
54493fc
open_lock
54493fc
open_lock
* This sketch uses the MFRC522 library ; see https://github.com/miguelbalboa/rfid
* for further details and other examples.
* NOTE: The library file MFRC522.h has a lot of useful info. Please read it.
* This sketch show a simple locking mechanism using the RC522 RFID module.
* Typical pin layout used:
* MFRC522 Arduino Arduino Arduino Arduino Arduino
* Reader/PCD Uno Mega Nano v3 Leonardo/Micro Pro Micro
* Signal Pin Pin Pin Pin Pin Pin
* RST/Reset RST 9 5 D9 RESET/ICSP-5 RST
* SPI SS SDA(SS) 10 53 D10 10 10
* SPI MOSI MOSI 11 / ICSP-4 51 D11 ICSP-4 16
* SPI MISO MISO 12 / ICSP-1 50 D12 ICSP-1 14
* SPI SCK SCK 13 / ICSP-3 52 D13 ICSP-3 15
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
String read_rfid;
String ok_rfid_1="A537EB54";
String ok_rfid_2="165FCE5E";
String ok_rfid_3="067AC65E";
String ok_rfid_4="544903FC";
String ok_rfid_5="454CF054";
//String ok_rfid_2=""; //add as many as you need.
int lock=7; //Led positive wich will light if rfid tag is OK
//Use the lines below if you plan on using a servo as a locking mechanism.
#include <Servo.h>
Servo myservo; // create servo object to control a servo
int posClosed = 100; // variable to store the servo position for locked
int posOpen = 7; //same for open...
* Initialize.
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
//Choose which lock below:
myservo.attach(2); // attaches the servo on pin 2 to the servo object
* Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
read_rfid="";
for (byte i = 0; i < bufferSize; i++) {
read_rfid=read_rfid + String(buffer[i], HEX);
void open_lock() {
//Use this routine when working with Servos.
myservo.write(7);
delay(2000);
myservo.write(100);
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
Serial.println(read_rfid);
Serial.println("open_lock");
if (read_rfid==ok_rfid_1) {
//ok, open the door.
open_lock();
if (read_rfid==ok_rfid_2) {
open_lock();
if (read_rfid==ok_rfid_3) {
open_lock();
if (read_rfid==ok_rfid_4) {
open_lock();
if (read_rfid==ok_rfid_5) {
open_lock();
//Add below as many "keys" as you want
//if (read_rfid==ok_rfid_2) {
//also ok, open the door
// open_lock();
// else not needed. Anything else is not ok, and will not open the door...
