Hello all,
I’m working on a project that requires a servo to rotate either direction in 60 degrees and then return to center quickly (a round trip back to center needs to be .4 sec or less). I have a futaba s3003 which is supposed to have a rotational speed of .19 sec/ 60 degrees on 6v power so I feel like a round trip should take close to .38 sec. However, it takes closer to 1 sec which is unacceptable. I am using 6v external power to power the servo so I don’t think this is an issue.
Here is the code:
#include <SoftwareServo.h>
SoftwareServo _servo;
int SERVO_PIN = 9;
int MAX_PULSE = 2000;
int MIN_PULSE = 800;
int CENTER = 90;
int ANGLE = 70;
int DELAY = 4;
void setup(){
_servo.attach(SERVO_PIN);
_servo.setMaximumPulse(MAX_PULSE);
_servo.setMinimumPulse(MIN_PULSE);
_servo.write(90);
void loop(){
wackClockwise();
wackCounterClockwise();
void wackCounterClockwise(){
for(int pos = CENTER; pos < CENTER + ANGLE; pos +=1){//move it to the right
_servo.write(pos);
delay(DELAY);
SoftwareServo::refresh();
for(int pos = CENTER + ANGLE; pos >= CENTER; pos -=1){//return it to center
_servo.write(pos);
delay(DELAY);
Serial.println(pos);
void wackClockwise(){
for(int pos = CENTER; pos > CENTER - ANGLE; pos -=1){//move it to the left
_servo.write(pos);
delay(DELAY);
for(int pos = CENTER - ANGLE; pos <= CENTER; pos +=1){//return it to center
_servo.write(pos);
delay(DELAY);
As you can see, this program repeatedly moves the servo 60 in one direction and then back to center, waits 1 sec then moves the servo 60 in the other direction then back to center. I am using the SoftwareServo library but the results are the same with the standard Servo.h library.
So my question is am I doing something wrong in the code? Moving a degree at a time seems like a clumsy way to control the servo but I can’t seem to get it to work any other way.
Should I just invest in a faster servo? If so do you have any suggestions? Price is not a big issue, it just needs to work well.
Thanks for the help
