Servo Rotation control
I am using 2 HX5010 180 degrees rotation motors for my first prototype of modular robotics.
In my project there are cubes which stick to each other and rotate against each other. I am using hall sensors to detect the orientation as well as the rotation.
The motors rotate fine only problem is I am not able to stop the motors in one position. I am unable to find where I am going wrong. If somthing could be done using code or the place ment of sensors are wrong.
Here is my code
#include <Servo.h>
Servo myservo1;
Servo myservo2;
//Servo myservo3;
const int  buttonPin1 = 2;    // Axthe pin that the pushbutton is attached to
const int  buttonPin1a = 3;  //Bx
const int  buttonPin2 = 4;    //Ay
const int  buttonPin2a = 5;    //By
//const int  buttonPin3 = 6;    //Az
//const int  buttonPin3a =7 ;    //Bz
const int serPin1 = 9;       // the pin that the servo is attached to
const int serPin2 = 10;
//const int serPin3 = 11;
//int lbs1 = 0;     // previous state of the button
//int lbse2 = 0;
//int lbs1a = 0;
//int lbs2a = 0;
int bs1 = 0;         // current state of the button
int bs2 = 0;         // current state of the button
int bs2a = 0;
int bs1a = 0;
//int bs3 = 0;
//int bs3a = 0;
int val= 180;
int val1= 0;
int temp;
int pos=0;
  myservo1.attach(9);
  myservo2.attach(10);
//  myservo3.attach(11);
  // initialize the button pin as a input:
  pinMode(buttonPin1, INPUT);
  pinMode(buttonPin1a, INPUT);
  pinMode(buttonPin2, INPUT);
  pinMode(buttonPin2a, INPUT);
//  pinMode(buttonPin3, INPUT);
//  pinMode(buttonPin3a, INPUT);
//  // initialize the LED as an output:
  pinMode(serPin1, OUTPUT);
  pinMode(serPin2, OUTPUT);
//  pinMode(serPin3, OUTPUT);
  // initialize serial communication:
  myservo1.attach(9);
//  digitalWrite(buttonPin1, HIGH);  // pull-up
//  digitalWrite(buttonPin1a, HIGH);
//  digitalWrite(buttonPin2, HIGH);
//  digitalWrite(buttonPin2a, HIGH);
  bs1= digitalRead(buttonPin1);   // LOW = 0 HIGH = 1
  bs1a = digitalRead(buttonPin1a);
  bs2 = digitalRead(buttonPin2);
  bs2a = digitalRead(buttonPin2a);
//  bs3 = digitalRead(buttonPin3);
//  bs3a = digitalRead(buttonPin3a);
  unsigned int keystate = 0;
  if (bs1 == HIGH) bitSet(keystate , 0);  // 1 - 1 (BIN)
  if (bs1a == HIGH) bitSet(keystate , 1);  // 2 - 10
  if (bs2 == HIGH) bitSet(keystate , 2);  // 4 - 100
  if (bs2a == HIGH) bitSet(keystate , 3);// 8- 1000
//  if (bs3 == HIGH) bitSet(keystate , 4); // 16- 10000
//  if (bs3a == HIGH) bitSet(keystate , 5);// 32 - 100000
//  Serial.print("STATE: ");
//  Serial.println(keystate, BIN);  // 0-15 = 0 - 1111
  temp= val;
  val = val1;
  val1 = temp;
  switch (keystate )
  case 1: // bs1 pressed others not
      myservo1.write(val1);              // tell servo to go to position in variable 'pos'
    delay(1500);                       // waits for the servo to reach the position
    Serial.println("Ax");
   myservo1.detach();
     delay(1500);
  case 2: // bs1a pressed others not
    delay(1500);
    Serial.println("B-x");
    myservo1.detach();
  case 4 : // bs2 pressed others not
    myservo2.write(val1);
    Serial.println("Ay");
    myservo2.detach();
  case 8: // bs2a pressed others not
    Serial.println("B-y");
    myservo2.detach();
  case 5: // bs1 and bs2 pressed others not
    Serial.println("AA");
     myservo1.detach();
   case 10: // bs1 and bs2 pressed others not
    myservo1.detach();
    myservo2.detach();
    Serial.println("BB");
   case 9: // bs1-Ax and bs2a-By pressed others not
   Serial.println("AxBy");
    delay(1500);
//     myservo1.write(val1);
//    delay(1500);
    Serial.println("AxAy");
    myservo1.detach();
    myservo2.detach();
   case 6: // bs1a-Bx and bs2-Ay pressed others not
   Serial.println("BxAy");
    delay(1500);
//    myservo2.write(val1);
//    delay(1500);
    myservo1.detach();
    myservo2.detach();
 case 0: // no keys pressed;
  default:  // invalid key combination
    // error message
    Serial.println("Invalid key combination pressed");
  myservo1.detach();
  myservo2.detach();
I want to know if my approach is correct. If not please let me know where am i going wrong.
What is that position?
If you are not able to stop them in that position, what other postions are you able to stop them in?
Can I suggest instead of all this:
that
  bitWrite(keystate , 0, digitalRead (buttonPin1));
  bitWrite(keystate , 1, digitalRead (buttonPin1a));
  bitWrite(keystate , 2, digitalRead (buttonPin2));
  bitWrite(keystate , 3, digitalRead (buttonPin2a));
would be neater and simpler?
(as a courtesy to readers, please remove all commented-out code before posting)
When the servo is in 0 degree, it is position A
When servo reaches 180 degrees, it is position B
I have placed 2 hall sensors on the block on one face, touching the face of another block. On one block one sensor towards A and another towards B. and on another block magnet towards one end corresponding to the positions of the magnet.
When the magnet is over A-hall sensor, it keep taking input and keep rotating. I want the servo to rotate only once and then not rotate till the magnet changes its position and comes over the hall sensor again
The last two "detach" in "loop" can never be reached - I don't imagine that is what you intended.
There's no need to initialise the servo pins as outputs - the library manages that for you.
Thanks I have made these changes.
I want the servo to stop. but as the loop runs over and over again it is reading the input again and again. I have tried using the detach function in Case but doesnot help. :frowning:
If you don't want the code to loop, put it all in setup which only runs once.
