Hello,
I make my first project whith an Arduino uno and Arduino motor shield,my pc windows 7 professionnal 64 bits.
I connectd 2 c.c. motors to motor shield, coming from an old ink-jet printer.
I cut the "VIN connect" on the back side of the shied, in order tu use an external power supply, 12V.
Until now everything works fine. I also use maxuino to control the 2 C.C. motors with Xbox controller for Pc , It is perfect.
The troubles starts when I tried to use a third motor witch is a Servo, connected on pins 5 or 6. The servo turn a little bit and then everything disconnect, the serial port is lost(com4).
I have to reconnect Arduino but the problem happen again.
Now when I come back to the arduino sorftware and use "exemples_servo_sweep", the servo works fine...
I thought the problem was firmata, when I send standard firmata to arduino , use the progam "firmata_test", The same problem happen, It works for the 2 C.C. motors but the serial port is lost afert a small servo rotation.
I also tried to use older vesions of firmata and an other external power supply (from a laptop 19.5V,4.7 A) whith no succes.
Can someone help me? Thank you
Etiennej1:
The servo needs more power than the Arduino 5V pin can provide. If you tried to power it from the 5V pin it would cause a reset.
Thanks john,
Do you know why the servo is working with the program “servo sweep” but not hand-controlled with “firmata test” or maxuino ?
and do you know where I have to connect the servo on Arduino motorshield to make it work ? My external power supply is 12v, the 2 C.C motors needs at least 12v and the servo need 6V. is there no solution?
Etiennej1:
Do you know why the servo is working with the program "servo sweep" but not hand-controlled with "firmata test" or maxuino ?
I confess that I do not know why that happens. Perhaps it is only a problem when the servo is asked to move a significant distance in one jump. Sweep uses 1-degree jumps and the Servo may never draw full power.
Etiennej1:
You can connect a servo to any pin. The motor shield uses 3, 8, 9, 11, 12, 13, A0, A1 so any other pin should work. The board has little three-pin connectors for Pins 5, 6, A2, and A3. Unfortunately the '5V' on those three-pin connectors comes from the Arduino. You can try using a 5V or 6V linear voltage regulator on the 12V supply to get power for the servo.
Thank you very much John, now it works!
