I use the code and the circuit for this project
I tried to use just the pin9 for the servo signal,ground,and 5v but the servo refuses to do a single move.I thought that the problem might be the connection so I tried to change cables and I realized that if I take the power wire and connect it back (not full connection,just a simple touch) the servo reacts for a small amount of time and stops.I tried to connect and disconnect but the servo only vibrates a moment .Am I missing something?
#include <SoftwareSerial.h> //Including the software serial library
#include <Servo.h> //including the servo library
SoftwareSerial esp(4, 5);
#define DEBUG true //This will display the ESP8266 messages on Serial Monitor
#define servopin 9 //connect servo on pin 9
Servo ser; //variable for servo
int current_pos = 170;
int v = 10;
int minpos = 20;
int maxpos = 160;
ser.attach(servopin);
ser.write(maxpos);
ser.detach();
esp.begin(115200);
sendData("AT+RST\r\n", 2000, DEBUG); //This command will reset module
sendData("AT+CWMODE=1\r\n", 1000, DEBUG); //This will set the esp mode as station mode
sendData("AT+CWJAP=\"wifi-name\",\"wifi-password\"\r\n", 2000, DEBUG); //This will connect to wifi network
while(!esp.find("OK")) { //this will wait for connection
sendData("AT+CIFSR\r\n", 1000, DEBUG); //This will show IP address on the serial monitor
sendData("AT+CIPMUX=1\r\n", 1000, DEBUG); //This will allow multiple connections
sendData("AT+CIPSERVER=1,80\r\n", 1000, DEBUG); //This will start the web server on port 80
if (esp.available()) //check if there is data available on ESP8266
if (esp.find("+IPD,")) //if there is a new command
String msg;
esp.find("?"); //run cursor until command is found
msg = esp.readStringUntil(' '); //read the message
String command = msg.substring(0, 3); //command is informed in the first 3 characters "sr1"
String valueStr = msg.substring(4); //next 3 characters inform the desired angle
int value = valueStr.toInt(); //convert to integer
if (DEBUG) {
Serial.println(command);
Serial.println(value);
delay(100);
//move servo to desired angle
if(command == "sr1") {
//limit input angle
if (value >= maxpos) {
value = maxpos;
if (value <= minpos) {
value = minpos;
ser.attach(servopin); //attach servo
while(current_pos != value) {
if (current_pos > value) {
current_pos -= 1;
ser.write(current_pos);
delay(100/v);
if (current_pos < value) {
current_pos += 1;
delay(100/v);
ser.detach(); //dettach
String sendData(String command, const int timeout, boolean debug)
String response = "";
esp.print(command);
long int time = millis();
while ( (time + timeout) > millis())
while (esp.available())
char c = esp.read();
response += c;
if (debug)
Serial.print(response);
return response;
