Servo shakes when URM37 scans
I am using the DFRobot Romeo all in one controller.
Allatched I have a servo with IR (Sharp) and Ultrasonic (URM37) sensors.
When I turn the servo 180° step by step and only read the IR Sensor at every step, the servo does a smooth round.
When I do a Ultrasonic Scan at every step, the servo starts to share as to be seen here: VID_20120620_073015.3gp - YouTube
The shaking seems to be especially strong when the scan distance is high (eventually higher than the 3m max range).
The board as well as the servo is powered via the Motor Power (11.1V LiPo).
I am using the milesburton library for the URM37. Sketch is attached.
Can someone explain what may go wrong?
Thanks,
Robert
robot.ino (8.82 KB)
You're busting your 20msec servo constraint.
Closer objects yield a response in a shorter time, but farther objects take more time to get a bounce back.
If you timeout earlier from those far objects (i.e. if it's not close, if no response before x, then it doesn't matter) then you can return to your servo routine before it goes jittery.
Thanks for your response.
Did I get it right? :
  • the servo need sconstant signaling from the board (every 20 ms?)
  • the scan takes longer and blocks the signaling
So I change the URM37 library and change the timeout from 200 to 20 or 19?
Is there a way to run the scan and the servo control in parallel?
I thougt the servo keeps its position without signal (as well as without power).
Thanks for the explanation.
Robert
OK. I found that the problem is most likely caused by the SoftSerial library (taking interrupts and interfering with the servo library). Because of this I would like to interface the URM37 via PWM.
There seemed to be some example code on yerobot.com . But the site is down.
Does someone have example code for the PWM mode? All I found is for serial communication.
Thanks
Robert
