servo signal problem
Hello!
I have a problem with sending proper signal to servo from transmitter through arduino DUE. I wrote a code like this:
#include<Servo.h>
Servo servo1;
int ch1;
int elevator;
pinMode(40,INPUT);
pinMode(31,OUTPUT);
servo1.attach(31);
ch1 = 2000;
ch1 = pulseIn(40,HIGH,25000);
if (ch1 <= 2800 && ch1>= 1600)
Serial.print(“Aileron:”);
Serial.println(ch1);
delay(100);
when I take out if statement, it gives signal of average 2200. With if statement it changes to 1800. I don’t understand why?
Thank you very much!
CheckWiring_ONLYONE.ino (430 Bytes)
That code, with or without the if() doesn't 'give' any average at all. What are you really looking at?
MorganS: That code, with or without the if() doesn't 'give' any average at all. What are you really looking at?
I know, when I open serial monitor, I'm receving numbers. It fluctuates somewhere between 2150 and 2250, but if I include the if statement (as above) numbers in serial monitor drop to around 1800.
Show us the second version of the code “without the if statement”. I don’t understand what you have removed or not removed.
Please use [ code ] tags. On the full editor (not quick-reply) the button looks like </>
#include<Servo.h>
Servo servo1;
int ch1;
int elevator;
 pinMode(40,INPUT);
 pinMode(31,OUTPUT);
 servo1.attach(31);
 ch1 = 2000;
 Serial.print("Aileron:");
  delay(100);
Without if statement it looks like this. I solved the problem. Problem was function pulseIn as I understood. I used Interrupts instead. Thanks!
