Servo signal reverser
Hlo can any one tell me the difference between..
( low voltage servo signal reverser and high voltage servo signal reverser)
I want to use MG995 servo motor..
which adapter can i use..?
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for advice on (nor for problems with) your project.
What exactly do you need the reverser to do ?
If you are controlling the servo with an Arduino then it is very unlikely that you need to use a reverser
Is nobody going to state the obvious??
One is low and the other is high voltage
:exploding_head:
Can You post links to their datasheets? The words "low" or "high" are not really scientific, more of emotional, not specifying any voltage.
A datasheet link to the servo You use could tell half the story.
If you intend to run the MG995 from a 5 Volt power source you can use the low volt reverser.
As others have said, why would you use a reverser if you use an Arduino.
The Arduino can do the same, better, and with more options if needed.
Leo..
