Servo starts at 30 degress
As you can see there is a big difference from my servo's 0 point and any other servo. This results in many of my formulas not to work and it also jams the servo once it overpasses it default maximum degree.
Thank you for your help!
P.S: My servo is not a continues rotation one.
Is that the angle of the arm on your servo?
The arms are removable, the shaft has a spline so, lift the arm and reposition it in the correct position.
Tom... :slight_smile:
To me it just looks like you did not place the plastic arm on in the right position... Just unscrew it and place it back right up when the servo is @ 0 degree.
Thanks, thought it was something serious :wink:
