Servo starts buzzing and wont react after first movement
Hi, so i'm making a RFID Door, with an XBEE shield and a NFC module. When a card shows up at the door, the servo turns, but wont do anything else after it, while it should close again after 5 seconds
#include <Servo.h>
byte data[5];  //For holding the ID we receive
int val = 0;
byte Marius[5] = {0x0D,0x00,0x58,0xF5,0xB7};
byte Gast[5]  = {0x0A,0x00,0x8B,0x9A,0xD9};
int servopin = 11;
int pos = 0;
//Create Servo Object
Servo voordeur;
   voordeur.attach(servopin);
   Serial.begin(19200);
   Serial.write(0xFF);  //Header
   Serial.write(0x01);  //Reserved
   Serial.write(0x09);  //Length (Command + Data)
   Serial.write(0x87);  //Command (0x87 sets auto mode behavior
   Serial.write(0x01);  //Data 1: Enable Auto-Read
   Serial.write(0x03);  //Data 2: Mode – Parity decoded – Manchester RF/64
   Serial.write(0x02);  //Data 3: Total number of block to be read (2)
   Serial.write((byte)0x00);  //Data 4: No password expected
   Serial.write(0x10);  //Data 5: Password byte 1
   Serial.write(0x20);  //Data 6: Password byte 2
   Serial.write(0x30);  //Data 7: Password byte 3
   Serial.write(0x40);  //Data 8: Password byte 4
   Serial.write(0x37);  //Checksum
   while(Serial.available()>0)
     Serial.read();
   Serial.println("Secured.");
   val = Serial.read();
   while (val != 0xff)
   {  //eerste byte is altijd 0xFF
   Serial.read();
   Serial.read();
   Serial.read();
   data[0] = Serial.read();
   data[1] = Serial.read();
   data[2] = Serial.read();
   data[3] = Serial.read();
   data[4] = Serial.read();
   Serial.read();
   boolean MC = true;
   boolean GC = true;
   Serial.print("gevonden kaart: "); //translate: found a card
   for (int i=0; i<5; i++)
     if (data[i] < 16) Serial.print("0");
     Serial.print(data[i], HEX);
     if (data[i] != Marius[i]) MC = false;
     if (data[i] != Gast[i]) GC = false;
   if (MC)
     Serial.println("Welkom Mario!"); //Translate Welcome Mario
     for (int i = 0; i < 12; i++)
     for(pos = 0; pos < 180; pos += 1)
    voordeur.write(pos);
    delay(5000);
  for(pos = 180; pos>=1; pos-=1)
  {  voordeur.write(pos);
   else if (GC)
     Serial.println("Hoi Gast!"); //translate Hello Guest
    delay(5000);
     Serial.println("Dief, Ga weg!"); //translate: Thief! go away
     for (int i = 0; i < 6; i++)
additional info:
When i try Sweep:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
                // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
  myservo.attach(11);  // attaches the servo on pin 9 to the servo object
  for(pos = 0; pos < 180; pos += 1)  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for(pos = 180; pos>=1; pos-=1)     // goes from 180 degrees to 0 degrees
It works but when i Change the delay to 5000 to get it to wait 5 seconds it wont turn at all
The delay is inside the for loop so it will delay 5000 millisecond every time through the loop. 180 * 5000 mS =900 second to go through the loop. Another way to look at is 5 seconds per degree.
Thanks for the answer! do you know where I have to place the delay for it to work properly?
Firstly, you don't have to sit in a delay while the servo does its job or move it one degree oat a time unless you need to slow it down for some reason. If it is at 0 and you want it to go to 180, just write 180 to it and it will go there as fast as it can (about 1 second). So in your case, when you want to open the lock try:
servo.write(180):
delay(5000);
servo.write(0);
I changed it to
servo.write(180);
delay(5000);
servo.write(0);
And the same problem appears. It gets stuck at the delay
Could it possibly be the powersource? (When the servo turns or is buzzing/shaking. The led on the NFC module is off and when i unplug the servo the led is back on
So it moves from 0 to 180 and stops? Did you take the for loop out? Please show the code you have to move the servo now. You are not powering the servo from the Arduino supply? That is not going to work. You need an external supply (5-6V) for the servo. 4 AA batteries will work. Connect battery, arduino and servo grounds together. Battery + to servo supply + .
#include <Servo.h>
byte data[5];
int val = 0;
int servopin = 11;
Servo voordeur;
     Serial.read();
   while (val != 0xff)
   Serial.read();
   Serial.read();
   Serial.read();
   Serial.read();
   boolean MC = true;
   boolean GC = true;
   if (MC)
       voordeur.write(180);
      delay(5000);
      voordeur.write(0);
   else if (GC)
     delay(5000);
      voordeur.write(0);
I'll try the external powersource tomorrow but i think that was it. I was powering the servo from the 5v output from the arduino
the loop itself should be as short as possible.
servo needs updating a lot so in loop it should say if open then servo.180 else servo.0
try to avoid any delay as timing is affected better use millis()
Notwithstanding the unfortunate fact that the tutorials or "Playground" suggest that it may be possible, in practice, you should never attempt to power a servo from the internal regulator in the Arduino. You may get away with using the Vcc terminal if you are deriving power from a USB port, but even that is inadvisable.
This is a common question here, and the answer is almost always the same - power servo from separate supply such as a 6V battery pack - and the bizarre and erratic problem disappears.
