Servo Steering control with dabble joystick (Bluetooth)
Hi all
I am trying to build a RC Car that uses a servo 9G motor for the steering.
I am using the dabble Bluetooth app to control the car. everything works better than I expected accept steering left.
the left position on the x axis is 0.00 to -7.00and i do not know how to read and write the float values to the servo
can some one please point me in right direction where i can learn to how to map float values to servo position.
thank you in advance.
here is a sample of my code where I'm stuck.
#define CUSTOM_SETTINGS
#define INCLUDE_GAMEPAD_MODULE
#include <Dabble.h>
#include <Servo.h>
Servo myservo;
//Motor
int r_en = 9;
int l_en = 12;
int Back = 10; //Back
int Forward = 11; //Forward
  myservo.attach(6);
  Dabble.begin(9600);
  pinMode(r_en, OUTPUT);
  pinMode(l_en, OUTPUT);
  pinMode(Back, OUTPUT);
  pinMode(Forward, OUTPUT);
  pinMode(6,OUTPUT);//servo
  Dabble.processInput();
  Serial.print('\t');
  float c = GamePad.getXaxisData();
  Serial.print("x_axis: ");
  Serial.print(c);
  Serial.print('\t');
  if (GamePad.getXaxisData()>=0){
    int value = GamePad.getXaxisData();
    if (value >=0){
      Serial.println(value);
      int servo_p = map(value,0,7,90,120); // last min and max is servo position in degrees
      myservo.write(servo_p);
  if (GamePad.getXaxisData()>=-0){
    if (value <=-0){
      int servo_p = map(value,-0,-7,90,60); // last min and max is servo position in degrees
Shouldn't that be:
if (GamePad.getXaxisData()<0){
Also, there is no reason to use -0. You have already assigned GamePad.getXaxisData() to a variable. There is no reason to call it over and over again just use the variable.
Hi Todd
Thanks for your input it got me thinking, I did some research and have got it right finally.
 float Joyx = GamePad.getXaxisData();
 Serial.println(Joyx);
 Serial.print('\t');
  if (Joyx >= 0.00){
    float value = Joyx;
    if (value >=0.00){
      float servo_p = mapfloat(value,0.00,7.00,90,120); // last min and max is servo position in degrees
    if (Joyx <= 0.00){
    float value1 = Joyx;
    if (value1 <=0.00){
      Serial.println(value1);
      float servo_p1 = mapfloat(value1,-7.00,0.00,60,90); // last min and max is servo position in degrees
      myservo.write(servo_p1);
float mapfloat(float x, float in_min, float in_max, long out_min, long out_max)
 return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
Glad you got it working! This:
  if (Joyx >= 0.00) {
    float value = Joyx;
    if (value >= 0.00) {
      float servo_p = mapfloat(value, 0.00, 7.00, 90, 120); // last min and max is servo position in degrees
  if (Joyx <= 0.00) {
    if (value1 <= 0.00) {
      float servo_p1 = mapfloat(value1, -7.00, 0.00, 60, 90); // last min and max is servo position in degrees
can be replaced by:
  float servo_p = mapfloat(Joyx, -7.00, 7.00, 60, 120);
Epic it worked like a charm. you did me a solid thanks.
