Servo stops when enter 0
Hello,
I have a project where I need to control a servo motor. The one I have is Futaba S3003. I want the servo to keep rotating until I enter 0 in the serial monitor. Is it possible? I thought of interrupts but the interrupts in arduino must be attachable and I want to avoid that. I am using Arduino Uno R3.
Here is my code:
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int state;
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  Serial.begin (9600);
  if (Serial.available () > 0)
    state = Serial.read ();
    if (state == '1')
      for (pos = 0; pos <= 180; pos += 1)
        myservo.write(pos);              // tell servo to go to position in variable 'pos'
        delay(15);
      for (pos = 180; pos >= 0; pos -= 1)
        delay(15);      // waits 15ms for the servo to reach the position
        if (state == '0')
          myservo.write ('90');
          delay (300);
In this code, the motor rotate once fully and then stops. I want it rotate fully all time until I enter 0
Can someone help?
Thanks to stackexchange, I found the solution:
New code:
#include <Servo.h>
int state;
if (state == ‘1’)
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(15);
else if (state == ‘0’)
myservo.write (‘90’);
delay (15);
Stackexchange link: http://arduino.stackexchange.com/questions/9287/stop-servo-when-enter-0?noredirect=1#comment17707_9287
