Servo - sweep just one time
Hi guys!
I would like to make next –
When I press the button, servo goes from 180 degree to 0, and returns to 180 (actually 179, because as I understood, constrain will return to max position only if it is lower than start position), just one time.
I was trying to figure out how to do this… So, is this correct way?
I'm not at home at this moment so I can't try it directly on board...
Thanks!
#include <Servo.h>
Servo myservo;
int button7=0;
int pos=180;
pinMode(7, INPUT);
myservo.attach(9);
void loop(){
button7=digitalRead(7);
myservo.write(position);
delay(5);
position=constrain(pos,0,179);
if(button7==1) {
position++;
delay(5);
position--;
You haven't declared the variable position.
Why is there a random delay(5)? Is that the time you expect the servo to make a 180 degree sweep? 5 millis?
if(button7==1) {
Should use HIGH, not 1.
And finally, this whole if statement is confusing and useless?
if(button7==1) {
position++;
delay(5);
position--;
No. If the Arduino is only supposed to move the servo through its range of motion, and back, two for loops are all that is needed.
You might want to look at the state change detection example, to see how to make the code do something when the switch BECOMES pressed, rather than IS pressed.
Thank you for your replies.
I was looking at servo sweep example and tried to change it in the way that I need.
So, here is the changed code.
#include <Servo.h>
Servo myservo;
int buttonPin = 7;
int buttonState = 0;
int oldButtonState = 0;
int position = 180;
  pinMode(buttonPin, INPUT);
  myservo.attach(9);
  myservo.write(180);
void loop(){
  buttonState = digitalRead(buttonPin);
  if ((buttonState == HIGH) && (oldButtonState == LOW)) {
    for(position = 0; position < 180; position += 1)
    for(position = 180; position>=0; pos-=1)
  oldButtonState = buttonState;
And? It does what you want? Or not?
void loop(){
    for(position = 0; position <=180; position += 1)   // position never reaches 180 here if you type <180
      myservo.write(position);                 // in the example code  there is a delay here
    for(position = 180; position>=0; position-=1)   // you mistyped pos here
      myservo.write(position);              // also a delay here in the example code
Since you write 180 to your servo motor in the setup, I think
you should swap the for statements. 180 first from 180 to 0 then 0 back to 180
siutoejai:
void loop(){
Thank's siutoejai, I've overlooked that.
It works just like I wanted!
Cheers mate!
