Servo 'Sweep' Program - Can I use MICROS instead of millis for delay?
I have a case where I’d like to have a float for the delay (i.e. delay of 15.5 milliseconds). This does not work in the sketch below. Is there a way to:
A. either make it work with a float
B. switch the time base to somethign finer (i.e. microseconds instead of millis)
/* Sweep
 by BARRAGAN <http://barraganstudio.com>
 This example code is in the public domain.
 modified 8 Nov 2013
 by Scott Fitzgerald
 http://www.arduino.cc/en/Tutorial/Sweep
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
    // in steps of 1 degree
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position
  for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
delayMicroseconds()
Servos work on an update rate of around 50Hz.
