I am playing around with the Servo sweep codes. How do I code it so that the servo makes a complete stop for #(seconds) before continuing its motion to reach the next position?
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(1); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
delay(15); // waits 15ms for the servo to reach the position
pause = 2000; // two seconds delay
delay(15); // waits 15ms for the servo to reach the position corrected
delay(pause);
delay(pause)
The delay(15) is a bit short for the servo's movement try changing that.
