Hello,
I control a servo with the librairies in Arduino 16 with a SPDT switch and a led as a monitor. I am using a mini pro 3.3v for control and feeding the servo with a battery pack. The servo keeps doing tiny random glitches even if I detach it in the code. Previously I was using a more complicated code with a duemilanove and it was not doing any glitches. I really want to simplify the code and stop those anoying little BZZZT! ? I tried a pull-up resistor between pin 9 and 5v but it was worse... If someone has an idea !! I thank you for reading my msg.
New code :
int Switch1=2;
int val=0;
int Ledpin=13;
#include <Servo.h>
Servo myservo;
pinMode(Switch1, INPUT);
pinMode(Ledpin,OUTPUT);
val = digitalRead(Switch1);
if (val == LOW){
digitalWrite(Ledpin, LOW);
myservo.attach(9);
myservo.write(0);
myservo.detach();
else {
digitalWrite(Ledpin, HIGH);
myservo.attach(9);
myservo.write(150);
myservo.detach();
Old code:
int Switch1=2;
int val=0;
int Ledpin=13;
int buttonState = 0;
int servoPosition = 0;
#define servo1control OCR1A
#define servo1null 2000
void setup(){
pinMode(9,OUTPUT);
TCCR1B = 0b00011010;
TCCR1A = 0b10100010;
ICR1 = 39999;
servo1control = servo1null;
void loop(){
if (val == LOW) {
if (buttonState == 0) {
if (servoPosition == 0) {
servo1control = 3750;
servoPosition = 1;
else {
servo1control = 2200;
servoPosition = 0;
buttonState = 1;
else {
buttonState = 0;
