Servo trouble (mooving at each loop)
Good evening to all
I am using a small servo (with a independant power source) however at each main loop it is slightly mooving without to have received any new angle order. The servo is useinside a code for a radio command .
I have test the servo , with a simple code , it is ok.
Any idea where it can comes from ?
thanks in advance
My code is :
#include <Servo.h>
Servo myservo;
#include <SoftwareSerial.h> // bibliothèque pour la voie série
SoftwareSerial mySerial(7, 6); // RX, TX // les broches de la voie série
#include <Wire.h> // bibliothèque
#include <Adafruit_Sensor.h> //bibliothèque pour le compas magnétique
#include <Adafruit_HMC5883_U.h>
Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
// Déclaration des variables
int message [19] = {}; //tableau à transmettre
double x = 0; //x brut du capteur
double y = 0; //y brut du capteur
double z = 0; //z brut du capteur
double checksomme =0; //Variable de vérification de la trame
String xstring = " ";
String ystring = " ";
String zstring = " “;
String check =” ";
String received;
int cardispo = 0;
String bit1;
String bit2;
String bit3;
String bit4;
String bit5;
String bit6;
String bit7;
int bit1_mod;
int bit2_mod;
int bit3_mod;
int bit4_mod;
int barre;
int barre_enr;
mySerial.begin(9600);
if (!mag.begin()) {
Serial.println(“Ooops, no HMC5883 detected … Check your wiring!”);
while (1);
sensors_event_t event;
mag.getEvent(&event);
x = event.magnetic.x;
y = event.magnetic.y;
z = event.magnetic.z;
checksomme = round(x)+round(y)+round(z) ;
//Serial.print (x);Serial.print (" “);Serial.print (y);Serial.print (” “);Serial.print (z);Serial.print (” ");Serial.println (checksomme);
xstring = String(x);
ystring = String(y);
zstring = String(z);
mySerial.print(xstring) ; mySerial.write(58) ;
mySerial.print(ystring) ; mySerial.write(59) ;
mySerial.print(zstring) ; mySerial.write(60) ;
mySerial.print(checksomme) ; mySerial.write(61) ;
loopIt:
if (mySerial.available() > 0) {bit1 = mySerial.read();} else {goto loopIt; };
bit2= mySerial.read();
bit3= mySerial.read();
bit4= mySerial.read();
bit1_mod = bit1.toInt();
bit1_mod =bit1_mod -48;
bit2_mod = bit2.toInt();
bit2_mod =bit2_mod -48;
bit3_mod = bit3.toInt();
bit3_mod =bit3_mod -48;
bit4_mod = bit4.toInt();
bit4_mod =bit4_mod -48;
barre=bit2_mod100+bit3_mod10+bit4_mod;
myservo.attach(10);
myservo.write(barre);delay(50);
myservo.detach();
//if (barre_enr!=barre){myservo.write(barre);barre_enr=barre; }
Serial.println(barre);
Serial.print(bit1);Serial.print(" “);Serial.print(bit2);Serial.print(” “);Serial.print(bit3);Serial.print(” “);;Serial.print(bit4);Serial.println(” ");
//while(Serial.available()>0 ){received = mySerial.read();}
///Serial.println (received);
delay (20);
How do you know there’s something to read here?
Please remember to use code tags when posting code
And please, goto is so 1950s
I imagine it's because you keep attaching and detaching the servo. When it is attached it tries to go to a default position and then moves to where your write sends it.
So why do you think you need to do that attach/detach over and over again? Normally you do the attach() once in setup() and there's rarely any need ever to use detach().
Steve
Good evening
in fact the part of code :
myservo.attach(10);
myservo.detach();
is only the way I found to avoid this trouble. (but I am loosing 50 ms)
why it is not working if I amusing only : myservo.write(barre);
I have try several things , and i am thinking the trouble comes from the reading on I2C
