Servo unnecessarily trying to reach an already reached angle.
In the code attached, I am trying to simply use two buttons on an IR remote to control the angle on a servo. That all works perfectly, but the problem lies when the servo does not stop trying to reach the angle specified(as it is obviously in a loop).
I am simple seeking a suggestion on an easy way to cut the power to the servo when it has already reached the desired angle… until the next button press. The servo makes a noise that sounds like it is struggling, and I don’t intend on using too much unnecessary power. Thanks!!
Servo_Controller.ino (682 Bytes)
UPDATE: Solved problem. Just had to detach the servo at the start of loop, and re attach it at the start of every if statement
Joshua10902:
There must be some other problem. It is not normally necessary to detach and re-attach servos.
How are you powering the servo? It should NOT be drawing power from the Arduino.
...R
Agreed. Power is worth checking.
If it is re-seeking, the variable that stores the servo position perhaps is being overwritten / reset or some other oddness. Is it declared static or global? That may be what it needs.
(not downloading ino code on my tablet - repost within code tags)
