Servo unwanted sweeping
Hi guys,
I am currently experimenting with a small 9g servo.
In my project, I simply have a button connected to toggle a variable which turns on and off an LED.
I also have a servo connected.
I want the servo to go to position 180 when the buttonState variable is High I want the servo to move to position 180 with incremental delays (Slower speed). So I used a for loop for this.
However, what I am getting is that the servo is moving to position 180 and then rotating back to 0 and then repeating.
I want to servo to stay at 180 while buttonState is High.
I am new to code so I am probably missing something simple.
I appreciate anyone who may advise.
Thank You.
#include <Servo.h>
//button connected to toggle state variable high/low
int inPin = 2;         // the number of the button input pin
int outPin = 13;       // the number of the button output pin
int buttonState = HIGH;      // the current state of the output pin
int reading;           // the current reading from the input pin
int previous = LOW;    // the previous reading from the input pin
long time = 0;         // the last time the output pin was toggled
long debounce = 200;   // the debounce time, increase if the output flickers
Servo myServo;
  pinMode(inPin, INPUT);
  pinMode(outPin, OUTPUT);
  myServo.attach(9);
  reading = digitalRead(inPin);
  // if the input just went from LOW and HIGH and we've waited long enough
  // to ignore any noise on the circuit, toggle the output pin and remember
  // the time
  if (reading == HIGH && previous == LOW && millis() - time > debounce) {
    if (buttonState == HIGH)
      buttonState = LOW;
      buttonState = HIGH;
    time = millis();
  digitalWrite(outPin, buttonState);
  previous = reading;
  for (int servoPosition=0; servoPosition <= 180; servoPosition++){
  myServo.write(servoPosition);
  delay(10);
Hi, A servo will usually go to the position you command as fast as it can.
You need something like the accelservo library to modify the servo acceleration:
http://www.airspayce.com/mikem/arduino/AccelStepper/
Have a look at how the servo is controlled in Several Things at a Time. Note that it is not using FOR
I think your problem is that your FOR always starts at 0 and I think you want to move from whatever the latest position might be.
...R
This line looks similar to the sweep example in the library.
Try looking at the pot example and modify that.
The servo sweeps with every iteration of loop() in your sketch. Add a condition to skip the sweep as long as the servo should stand still.
sutty5:
Depending on what your overall intention was, maybe…
    time = millis();
  } // <--- ...this brace...
  delay(10);
 } // ...was intended to be here?
