this is my first micro-controller project ever, and i have no C experience, so i opted to take the cautious but ineffecient route, hence using longs for tons of values that could have been ints or bytes, to avoid any silly or unexpected mistakes or compatibility errors.
I threw a ton of serial write commands in there to see whats up, and the timing seems to claim i only get 1 servo pulse per run of the loop function, not a continuous train. i removed all those things for readability.
#include <Servo.h>
Servo LDrive;
Servo RDrive;
int ch0Pin = 15; //first channel
int ch1Pin = 16;
int ch2Pin = 17;
int ch3Pin = 18;
int ch4Pin = 19;
int ch5Pin = 20;
int LControllPin = 13; //to motor controlls
int RControllPin = 14;
unsigned long RCin[7]; //8 channel RC remote
for (int ii = 0; ii < 8; ii++){
RCin[ii]=1500;}
pinMode(ch0Pin, INPUT);
pinMode(ch1Pin, INPUT);
pinMode(ch2Pin, INPUT);
pinMode(ch3Pin, INPUT);
pinMode(ch4Pin, INPUT);
pinMode(ch5Pin, INPUT);
LDrive.attach(LControllPin);
RDrive.attach(RControllPin);
// prints initial value on chan 0 and says hi
Serial.println(RCin[0]);
Serial.println("Setup Complete");
void loop(){
long tP = 0;
long directional = 0;
long lP = 0;
long rP = 0;
long rT = 0;
long lT = 0;
long lServ = 90;
long rServ = 90;
RCupdate();
directional = ABProfile();
tP = throttlePerc();
lP = directional/1000;
rP = directional-lP*1000;
lT = lP*tP/100;
rT = rP*tP/100;
lServ = map(lT, -150, 150, 0, 180); //maps left drive percent (signed) to servo degrees, assumes 90 deg = 1500 us pulse
rServ = map(rT, -150, 150, 0, 180); //defaults set servo max min to 544 2400
LDrive.write(lServ);
RDrive.write(rServ);
void RCupdate(){
RCin[0] = pulseIn(ch0Pin, HIGH); //throttle
RCin[1] = pulseIn(ch1Pin, HIGH); //aile
RCin[2] = pulseIn(ch2Pin, HIGH); //elev
RCin[3] = pulseIn(ch3Pin, HIGH);
RCin[4] = pulseIn(ch4Pin, HIGH); //gear
RCin[5] = pulseIn(ch5Pin, HIGH);
long throttlePerc(){
int neutral = 1500;
long Tp; //throttle percent, with sign
if(RCin[2]==0)
Tp=0; //failsafe
if(RCin[2]>neutral)
Tp=((long)RCin[2]-neutral)/5;
if(RCin[2]<=neutral && RCin[2]!=0)
Tp=-(neutral-(long)RCin[2])/5;
return Tp;
long ABProfile(){
long D = (long)RCin[1]; //aileron (chan 3) value
long Rp = 0; //Right throttle percent value
long Lp = 0; //Left
long DirP = 0; //merged to pass as output, lp,rp
long ap = 10; //percent of knees as read on remote monitor
long bp = 25;
long cp = 85;
long eep = 150; //overange cutoff
long a = ap*100000/131; //percent 1000 to perserve accuracy
long b = bp*100000/131; //ex is 19084
long c = cp*100000/131;
long ee = eep*100000/131; //max 15,000,000/131 of 2,100,000,000
long taPos = 1500+500*a/100000;
long tbPos = 1500+500*b/100000;
long tcPos = 1500+500*c/100000;
long teePos = 1500+500*ee/100000;
long taNeg = 1500-500*a/100000;
long tbNeg = 1500-500*b/100000;
long tcNeg = 1500-500*c/100000;
long teeNeg = 1500-500*ee/100000;
if (D<taPos) Rp= 100;
if (taPos<=D && D<tbPos) Rp= 100-(D-taPos)*1293/1000;
if (tbPos<=D && D<tcPos) Rp= 25 -(D-tbPos)*219/1000;
if (tcPos<=D && D<teePos) Rp=-25 -(D-tcPos)*426/1000;
if (teePos<=D) Rp= -150;
if (D>taNeg) Lp= 100;
if (taNeg>=D && D>tbNeg) Lp= 100+(D-taNeg)*1293/1000;
if (tbNeg>=D && D>tcNeg) Lp= 25 +(D-tbNeg)*219/1000;
if (tcNeg>=D && D>teeNeg) Lp=-25 +(D-tcNeg)*426/1000;
if (teeNeg>=D) Lp= -150;
DirP=Lp*1000+Rp;
return DirP;
on the bright side i now know enough about registry thingys to konw what i need to make the fast PWM configed properly I THINK, but not enough to fully undertand the servo.h code to make sure it is setting up my timer and prescaller and all that fun stuff properly. untill a knight in armor swaggers thru this thread, i am going to learn about hand-modifying those values and see if i can't beat it into submission, but the fact the sweep demo seems to work fine makes me think its not a servo.h issue, although if i threw a long delay into the demo program, that would tell me if slowing down the loop slows down the pulse train, meaning the PWM is not working as it should be.
