Servo-(Vigor VTS-08B) Problem
Hello,
I have a servo Vigor VTS-08B http://www.vigorprecision.com.hk/uploadfile/20120530/20120530173655378.pdf.
I am using the following code to command the servo via serial monitor move to a specific angle.
  Servo Test Code
  Bascially user inputs no. between 0-180 from the serial monitor
  Arduino turns the servo to that position
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
  // Begin Serial library
  // attaches the servo on pin 6 to the servo object
  myservo.attach(6);
  // Whenever there is some data input from serial monitor, i.e whenever user enters a number(position)
  // command arduino to move to the postion
  if(Serial.available())
    // Move the servo to the postion as specified by user
    myservo.write(Serial.parseInt());
    // wait for some time
Problem is that whenever i enter a number it moves to that angle (also not so accurately) and when it stops it constantly make a noise for a few seconds. And when I enter an angle again less than the previous angle I entered it moves reverse to 180 deg first than goes to the angle entered. Eg. First I move the servo to 135 deg by entering 135 in the serial. It moves to that angle but it still makes a constant sound for a few seconds than stops. And when I enter a smaller angle say 90 deg , ther servo first goes to 180 deg than to 90 deg.
I am using Arduino Uno with an external supply from an AC to DC adapter capable of providing 5.5V and 500mA. And Arduino UNO is being powered via my laptop's USB . No load is attached to Servo motor.
Also I have another motor V3003 (datasheet not available online) . It works perfect and does not give me the above problem. This Servo requires less power than above. So i think Code works fine.
Please help me. Any more queries are welcome.
Thanks in advance
That servo takes an amp or more, giving it 0.5A will lead to issues.
First of all thank you for such a quick reply.
I will try a higher current rating power supply. Can anyone suggest any from their experience. It would be a lot help. Thank you
