Servo weirdness...
I’m using the fantastically sweet Servo library!
The problem is when I add more than 1 servos, the whole thing haults. My connected LEDs stop changing colors, the other servo halts. If I run the exact same compile just with the 2nd servo disconnected, it runs without a hitch.
I’m currently using 2 servos: on pins 9 and 10, but I’m using the Servo library because I plan on working up to many servos (24!)
Any idea why the thing haults with more than 1 servo plugged in?
Thanks so much
Lee
sounds like you have run out of available current. Try using an external 5 or 6 volt power supply to run the servos.
D
