I'm making a warhammer model that has several servos inside of it. 2 of the 3 servos are working fine but the third seems to always jump from 0 to 180 (actually seems to be more than 180 degrees) regardless of the input I give it. It also seems to want to go further than 0,180 where you'll here it hitting its limits.
I'm running an Nano 33 IOT currently have the servo hooked up to a DC power supply set to 5.5v with common ground to my Arduino thats powered by double A batteries.
I've tried several different scripts, I've attached one below. I've tried limiting the range in the Attach statement, but no matter what the input is it always either goes to 0 or 180.
With default Attach args I get some really inconsistent behavior.
If i enter 550 it goes to what I assume is the 0 degrees.
If i enter say 600 nothing happens.
If i enter 650 it then goes all the way to what i assume is 180 degrees
If i enter 550 and then 800 it will go to 0 and then 180 but then if i enter 650 it goes back to 0
Any advice here would be great. I unfortunately didnt spend enough time testing the servo before I built the model, I knew it worked but didnt look closely at its behavior So i'm in a position where I cant replace the servo.
Thanks
Try this test sketch with the Servo library to see how your
servo responds to different settings, type a position
(0 to 180) or if you type a number greater than 180 it will be
interpreted as microseconds(544 to 2400), in the top of serial
monitor and hit [ENTER], start at 90 (or 1472) and work your
way toward zero (544) 5 degrees (or 50 micros) at a time, then
toward 180 (2400).
#include <Servo.h>
Servo servo;
// initialize serial:
Serial.begin(9600); //set serial monitor baud rate to match
servo.write(0);
servo.attach(8);
prntIt();
// if there's any serial available, read it:
while (Serial.available() > 0) {
// look for the next valid integer in the incoming serial stream:
int pos = Serial.parseInt();
pos = constrain(pos, 0, 2400);
if (pos > 544) {
servo.write(pos);
prntIt();
void prntIt()
Serial.print(" degrees = ");
Serial.print(servo.read());
Serial.print("\t");
Serial.print("microseconds = ");
Serial.println(servo.readMicroseconds());
Thats correct. I have a large script that runs everything, the code of all 3 is very similar, but one of the 3 servos didnt work. So i created a much simpler project to test out the 1 failing servo which is the code I linked above.
I also just bought another servo and hooked it up and it works as expected so I fear something is wrong with that servo. Its just weird that it moves but only 0 and 180. I also noticed for lower requested angles (say 20 degrees) it moves to 180 much slower than if i asked for 50 degrees
Here 600 keeps it at 0 degrees, 700 sends it to 180. This code uses the writeMicroseconds. Script below.
Unfortunately the actual wiring is hidden inside of the model so it cant be seen. I'm looking up how to make those pretty images now.
toward 180 (2400).
#include <Servo.h>
Servo servo;
servo.write(0);
servo.attach(8);
prntIt();
if (pos > 544) {
servo.writeMicroseconds(pos);
Serial.print("pos: ");
Serial.println(pos);
prntIt();
void prntIt()
Serial.print("\t");
Yes, bought them all through amazon as a single package. They are SG90s. I was actually able to take apart the model and take it out and replace it. Going to test it thoroughly before I close it up.
Previously I was running the servo's off of the same power supply the arduino was recieving, 2x3.7v AA batteries. Instead now I'm going to give these servos their own dedicated 2x3.7v batteries with common ground to the arduino and a DC stepdown to ensure I'm getting 5.5v.
I'm guessing I somehow damaged the servos, i'm really not sure.
