Servo working but 2 DC motor is not working but making sound “ pew”
Pls. advice.
Arduino UNO+L293D+2 DC Gear Motor+ 1 no sonar sensor+ 1 no servo.
Servo working but 2 DC motor is not working but making sound “ pew”. Is it anything frequency declaration
AF_DCMotor motor1 (3, MOTOR34_8KHZ) or some other issue?
Here is my code for projects,
#include <AFMotor.h>
#include <Servo.h>
#include <NewPing.h>
#define TRIG_PIN A4 // Pin A4 on the Motor Drive Shield soldered to the ultrasonic sensor
#define ECHO_PIN A5 // Pin A5 on the Motor Drive Shield soldered to the ultrasonic sensor
#define MAX_DISTANCE 200 // sets maximum useable sensor measuring distance to 200cm
#define MAX_SPEED 180 // sets speed of DC traction motors to 180/256 or about 70% of full speed - to get power drain down.
#define MAX_SPEED_OFFSET 10 // this sets offset to allow for differences between the two DC traction motors
#define COLL_DIST 10 // sets distance at which robot stops and reverses to 10cm
#define TURN_DIST COLL_DIST+10 // sets distance at which robot veers away from object (not reverse) to 20cm (10+10)
NewPing sonar(TRIG_PIN, ECHO_PIN, MAX_DISTANCE); // sets up sensor library to use the correct pins to measure distance.
AF_DCMotor motor1(3, MOTOR34_8KHZ); // create motor #1 using M1 output on Motor Drive Shield, set to 1kHz PWM frequency
AF_DCMotor motor2(4, MOTOR34_8KHZ); // create motor #2, using M2 output, set to 1kHz PWM frequency
Servo myservo; // create servo object to control a servo
int pos = 0; // this sets up variables for use in the sketch (code)
int maxDist = 0;
int maxAngle = 0;
int maxRight = 0;
int maxLeft = 0;
int maxFront = 0;
int course = 0;
int curDist = 0;
String motorSet = "";
int speedSet = 0;
//-- SETUP LOOP --
myservo.attach(9); // attaches the servo on pin 9 (SERVO_2 on the Motor Drive Shield to the servo object
myservo.write(90); // tells the servo to position at 90-degrees ie. facing forward.
delay(2000); // delay for two seconds
checkPath(); // run the CheckPath routine to find the best path to begin travel
motorSet = "FORWARD"; // set the director indicator variable to FORWARD
myservo.write(90); // make sure servo is still facing forward
moveForward(); // run function to make robot move forward
//--MAIN LOOP --
checkForward(); // check that if the robot is supposed to be moving forward, that the drive motors are set to move forward - this is needed to overcome some issues with only using 4 AA NiMH batteries
checkPath(); // set ultrasonic sensor to scan for any possible obstacles
void checkPath() {
int curLeft = 0;
int curFront = 0;
int curRight = 0;
int curDist = 0;
myservo.write(144); // set servo to face left 54-degrees from forward
delay(120); // wait 120milliseconds for servo to reach position
for(pos = 144; pos >= 36; pos-=18) // loop to sweep the servo (& sensor) from 144-degrees left to 36-degrees right at 18-degree intervals.
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(90); // wait 90ms for servo to get to position
checkForward(); // check the robot is still moving forward
curDist = readPing(); // get the current distance to any object in front of sensor
if (curDist < COLL_DIST) { // if the current distance to object is less than the collision distance
checkCourse(); // run the checkCourse function
break; // jump out of this loop
if (curDist < TURN_DIST) { // if current distance is less than the turn distance
changePath(); // run the changePath function
if (curDist > curDist) {maxAngle = pos;}
if (pos > 90 && curDist > curLeft) { curLeft = curDist;}
if (pos == 90 && curDist > curFront) {curFront = curDist;}
if (pos < 90 && curDist > curRight) {curRight = curDist;}
maxLeft = curLeft;
maxRight = curRight;
maxFront = curFront;
void setCourse() { // set direction for travel based on a very basic distance map, simply which direction has the greatest distance to and object - turning right or left?
if (maxAngle < 90) {turnRight();}
if (maxAngle > 90) {turnLeft();}
maxLeft = 0;
maxRight = 0;
maxFront = 0;
void checkCourse() { // we're about to hit something so move backwards, stop, find where the empty path is.
moveBackward();
moveStop();
setCourse();
void changePath() {
if (pos < 90) {veerLeft();} // if current pos of sensor is less than 90-degrees, it means the object is on the right hand side so veer left
if (pos > 90) {veerRight();} // if current pos of sensor is greater than 90-degrees, it means the object is on the left hand side so veer right
int readPing() { // read the ultrasonic sensor distance
delay(70);
unsigned int uS = sonar.ping();
int cm = uS/US_ROUNDTRIP_CM;
return cm;
void checkForward() { if (motorSet=="FORWARD") {motor1.run(FORWARD); motor2.run(FORWARD); } } // make sure motors are going forward
void checkBackward() { if (motorSet=="BACKWARD") {motor1.run(BACKWARD); motor2.run(BACKWARD); } } // make sure motors are going backward
// In some cases, the Motor Drive Shield may just stop if the supply voltage is too low (due to using only four NiMH AA cells).
// The above functions simply remind the Shield that if it's supposed to go forward, then make sure it is going forward and vice versa.
void moveStop() {motor1.run(RELEASE); motor2.run(RELEASE);} // stop the motors.
void moveForward() {
motor1.run(FORWARD); // turn it on going forward
motor2.run(FORWARD); // turn it on going forward
for (speedSet = 0; speedSet < MAX_SPEED; speedSet +=2) // slowly bring the speed up to avoid loading down the batteries too quickly
motor1.setSpeed(speedSet+MAX_SPEED_OFFSET);
motor2.setSpeed(speedSet);
delay(5);
void moveBackward() {
motorSet = "BACKWARD";
motor1.run(BACKWARD); // turn it on going forward
motor2.run(BACKWARD); // turn it on going forward
delay(5);
void turnRight() {
motorSet = "RIGHT";
motor1.run(FORWARD); // turn motor 1 forward
motor2.run(BACKWARD); // turn motor 2 backward
delay(400); // run motors this way for 400ms
motor1.run(FORWARD); // set both motors back to forward
void turnLeft() {
motorSet = "LEFT";
motor1.run(BACKWARD); // turn motor 1 backward
motor2.run(FORWARD); // turn motor 2 forward
void veerRight() {motor2.run(BACKWARD); delay(400); motor2.run(FORWARD);} // veering right? set right motor backwards for 400ms
void veerLeft() {motor1.run(BACKWARD); delay(400); motor1.run(FORWARD);} // veering left? set left motor backwards for 400ms
Hi
Welcome to the Forum
http://forum.arduino.cc/index.php/topic,148850.0.html
then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Here is the picture for my project, ckt diagram and component.
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Have you got some code that just drives the motors?
Check the Examples in the IDE for AF_DC examples.
I hope you developed this code in stages.
  1. Coded soanar and got it working.
  2. Coded drive control and got it working.
  3. Combined the two and got them working.
Do you have any code where your motors worked?
Tom... :slight_smile:
You need a much stronger power supply for the motors, a 9V block battery is way too weak for that.
If you lift your car off the floor, do the wheels spin?
Nop, when lift from floor, not spin.
Thanks Tom
i had code to run motor with LN298D and tested ok. But working with servo and dc motor using LN293D driver facing such problem.
Regarding much stronger power, what type of battery should i use?
What's the nominal voltage and current of your motors?
The battery should have about twice that voltage, and current for the intended time of operation, e.g. more than 2000mAh.
Tom,
Here is the info from motor...
This gear motor wheel is perfect for your robotics project. This gear motor is ideal for robotic car or line-tracing robot. With plastic construction and colored in bright yellow, the DC gear motor measures approx. 2.5 inch long, 0.85 inch wide and 0.7 inch thick . The wheel can be mounted on either side and the gearmotor works well between 4V to 7V (recommended 6 Volts). At a ratio of 1:48 you can get some really good torque at 5 Volts.
Motor Specifications:
1 X Virtuabotix Yellow DC Gearmotor
Operating voltage: 3V ~ 12V DC (recommended value is 6 ~ 8V)
Maximum torque: 800g.cm (3V)
Speed without load: 170 RPM (3V)
Reduction ratio: 1:48
Load current: 70mA (250mA MAX) (3V pm)
With the L239 driver the battery voltage should be at least 6V, better 8V for the recommended 6V motor operation. 500mAh will be sufficient for these low power motors, when the current is limited to 250mA each. Higher capacity may be better.
Thanks TOM.
Thanks for your kind advice.
Is is solved with Higher Battery Capacity (6/9V, 2000mA)
Well done DrDiettrich, for the follow up.
+1 Karma
Thanks Tom, for mentioning the Karma points!
At least one person found my contributions worth a point. Should I stop contributing, if my comments are seemingly worth nothing to a thread opener?
