Hi, I am building an arm on top of a tracked vehicle. I am using the motor shield to drive the tracked vehicle motors and have servo's attached to Arduino. Due to the power requirements of the servo's they have a seperate positive but common ground with the Arduino board. Attached directly to the Arduino, the servo's work perfectly and follow a test sequence I have configured.
However when I attach the motor shield, the servo attached to pin 10 moves erratically as though it's getting chatter from the board rather than following the test sequence. As far as I can see the motor shield simply passes pin 10.
Any thoughts would be most appreciated.
